Question about Philips Televison & Video
. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
TV
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
please do rate the solution positively.thanks
Posted on Mar 22, 2010
Testimonial: "thank u very much for cooperation and the solution is very helpful."
SOURCE: Philips PM3S - 3-Device Universal Remote Control
Here is your product manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000053128.pdf
It includes the codes for your remote. :}
If you dont see your product on the code list try a code search. If this fails your remote might not support your device.
Posted on Dec 17, 2007
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: philips universal tv remote not working
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
SOURCE: wallis universal cm101 remote control
may find this link usefull http://www.sosremotes.com/
Posted on Feb 05, 2010
Dec 03, 2015 | Philips Televison & Video
Aug 25, 2012 | Universal Remote Control URC-200 LCD...
Sep 04, 2009 | Televison & Video
Jun 12, 2009 | Philips PMDVD6 Remote Control
Feb 10, 2009 | Philips Universal PH301S Remote Control
Feb 09, 2009 | Philips Universal PH301S Remote Control
Jan 23, 2009 | Televison & Video
Sep 03, 2008 | Philips 5-Device Universal Learning Remote...
Apr 06, 2008 | Philips Universal PH301S Remote Control
Jan 15, 2021 | Philips Televison & Video
1,178 people viewed this question
