Question about Whirlpool Safety Bath Walk In Bathtub - Stretch Without
Jets don't work in the jetted tub.
We used our new jetted tub and the jets didn't turn on. There is no instruction manual.
Posted by julie_moomaw on
Anonymous
    New Friend:
  • 11 Answers
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Posted on Mar 23, 2010
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Aug 16, 2011 | Home
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
We have purchased a whirlpool tub model # 1714019020. It has side jets & 4 jets at the back. Can you tell me if there is some way to adjust the back jets or to turn them off as they spray water everywhere...
Some jets you can stick your finger into the jet its self and move it in 360 degrees. Others have a notched round trim piece that when turned counter clockwise, will loosen the jet where you can manipulate it as described above. You will need to retighten it after your done so it doesn't end up the same way. If you have trouble, you may want to use a little spray lubricant on it so it will loosen.
Mar 31, 2009 | American Standard Home
Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Dec 04, 2008 | Home
Whirlpool Safety Bath Walk In Bathtub - Stretch Without Logo
1,277 people viewed this question
Top Whirlpool Home Experts
john h
Mike
Andrew Taylor
Andrew Taylor
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
