First of all you should try it on deferent pc , if its ok then thatleads us to insufficient power provided through usb ports , try usingback usb ports not the ON-front, and if the problem still try usingdual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.htmland if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changedif you cant find a similar one you may buy a new empty cage
If it is new external hard drive, please follow these steps:
click Start,
1. right click "my computer"
2. click "manage"
3.Now there a new window that popped up, click the "disk management"
4.You should see your removable disk.
Now, format the new hard drive and after that it would be detected.
SOURCE: drop my external hard drive computer not reading the drive
Hi there
when you dropped it you probably jarred it and the plates inside have got scratched which made it unusable.. it is a pretty sensitive unit it does not take much to ruin a external drive.. i am sorry but i think replacing this drive is what you are going to have to do ok
best regards mike
SOURCE: computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
SOURCE: Computer will not locate external hard drive
Right click on your "my computer" icon in XP, or the word "Computer" on Vista/7, go to manage. On the window that opens up go to storage>disk management. Is it showing up in that list?
If you are using a Mac, go to your utilities folder and run system profiler. Does your drive show up under the usb devices tree?
If its linux, which distro are you using?
Does the drive work on any other computer? If not, I would suspect a bad drive, or a bad enclosure, or just an un-initialized drive, which can be fixed in windows by right clicking on the drive in that list and clicking intialize. In mac run the Disk Utility from the utilities folder and click the drive and select format.
In the future, pls specify your OS. thanks!
SOURCE: Sony Vaio laptop could not access 1TB external hard drive
Check the Disk Manager in Windows to see if the drive is formatted and has a drive letter assigned.
Also see further troubleshooting on external hard disks.
SOURCE: verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
