Neff H7871N2GB Convection / Microwave Oven Logo
sally hirst Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The inner door glass shattered and now no power
Neff HFT879 the inner door glass shattered and now no power. I have changed the glass, checked the fuse still no power.
  • Anonymous Mar 23, 2014
    NO POWER SUPPLY. HAVE CHANGED PLUG FUSE?
Bob Korsu
Level 3:
Guru:
  • Master 1,051 Answers
  • Posted on Mar 22, 2010
Bob Korsu
Master
Level 3:
Guru:
Answers
1051
Questions
0
Helped
403220
Points
3047
There's a safty switch which prevents the unit from operating if the door isn't fully closed. When the glass shattered a small piece may have blocked the switch from operating properly. Check around the door seals for any irregularities.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1772
Points
Can you advise where you purchased the glass door and how you replaced it contact me on [email protected], thanks
How do I replace the inner door glass on a neff C67M70 microwave
Not easy. All microwave repairs should be done by a professional. Oven doors are easy, but they make microwaves harder because they need to be sealed and checked for radiation leaks. Traditional ovens are easy, microwaves aren't.
https://www.google.com/search?q=replace+the+inner+door+glass+on+a+neff+C67M70+microwave
Neff combi oven - Cuts out after replacing glass in door Neff C67M70N3GB
I have two thoughts, both guesswork based on knowledge gained by researching answers here on Fixya.
If you removed the door completely, the safety microswitches need re-adjusting. The door and hinges usually has three or sometimes 4 to make it impossible to use the oven with the door open.
Or, modern ovens have a safety catch under the glass edges that won't allow the oven to work if there is NO glass on the inside, or no glass on the outside. In other words, there must be 2 (or 3) panes of glass to stop children, old folks and pets getting burned by door glass that is the same temperature as a oven.
The final possibility is that the microwave failing is coincidental and not related to the door glass being replaced!
1helpful
Neff b6774N0gb/02. Inner glass shattered. replaced. Internal fuse blown. replaced. Now microwave working (heating water) for approx 5 sec, then switching off, beeping and showing E1 fault. Also display...
Usually if this model stops after approx 3 secs it is an invertor or mag fault. Check that the aerial cover is clean Page 3 of the breakdown part position 315. If this is really grubby it would be the cause of the door shattering. The PTC is not used on the microwave function so may be an additional fault. Check also the alignment of the door switches as this can also cause a similar fault. My best guess is if you remove the mag, you'll probably find scorching on it and it (and the invertor) will need replacing.
1helpful
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
5helpful
Glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
1helpful
3answers
Neff H7871 inner glass broken
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL ([email protected])
Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Microwave door shattered
Give is the entire model # on the sticker inside the microwave and I should be able to help.
Top Neff Microwave Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Tracy
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
