Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I wire a four pin plug for a CB? - Galaxy Radios DX-99V 40-Channels Base CB Radio
Anonymous
Level 3:
Genius:
  • Master 1,274 Answers
  • Posted on Mar 22, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1274
Questions
0
Helped
315867
Points
3479
Try this, 1.shield-ground,2.yellow-audio,3.red-transmit,4.white-recieve. ..hope this helps..
How to wire a Sadelta M3 to a Cobra 29 LTD Classic
I believe to wire a Sadelta M3 microphone to a Cobra 29 LTD Classic CB radio:
The Sadelta M3 microphone has four wires: white, shield (bare wire), red, and black. The Cobra 29 LTD Classic CB radio's microphone jack also has four pins: Pin 1 (Audio), Pin 2 (Ground), Pin 3 (Transmit), and Pin 4 (Receive).
To wire the Sadelta M3 to the Cobra 29 LTD Classic, you need to connect each wire from the microphone to its corresponding pin on the microphone jack. The white wire carries the audio signal from the microphone's element to the radio, the shield wire provides a ground connection, the red wire activates the radio's transmit function when the microphone is keyed, and the black wire is used for receive audio.
Here are the specific steps to follow:
  1. Cut off the existing microphone plug on the Sadelta M3 microphone cord.
  2. Strip about 1/4 inch of insulation from each of the four wires in the Sadelta M3 microphone cord.
  3. Connect the wires to the pins on the microphone jack as follows:
  • White wire to Pin 1 (Audio)
  • Shield (bare wire) to Pin 2 (Ground)
  • Red wire to Pin 3 (Transmit)
  • Black wire to Pin 4 (Receive)
  1. Solder each wire to its corresponding pin on the microphone jack. You may want to use a multimeter to verify that each connection is solid and that there are no shorts or open circuits.
  2. Once you have soldered all the wires, test the microphone by speaking into it and checking that the radio's TX meter moves as you speak. Also, check that you can hear audio through the radio's speaker when receiving signals.
  3. If the microphone is working correctly, use heat shrink tubing or electrical tape to cover the soldered connections and provide strain relief for the wires.
Note that some microphones, including the Sadelta M3, may have additional features such as a built-in amplifier or power supply that require additional wiring.
Radio Shack TRC 47. What are color codes for the 5-pin mic?
did you cut the wire to the mic plug . 99% of R.S. mics are wired the same. there are some four pin and 6 pins but basically all the din type plugs are the same.
Mic wiring diagram
Try this, looking at the mic connector from the wire side and going counter-clockwise starting in the four oclock position: PIN 1 sh, PIN 2 wh, PIN 3 bk, PIN 4 rd.
How to wire a road king 56 to a midland powe max cb radio four pin plug
one wire is ground,one wire is tx one wire is rx,so now all you have to do is find which wire goes where. do you have a multi meter? put one end into the antenna plug on the radio now put you meter on sound for an ohms reading and touch the pins .If the pin makes a loud clear sound thats your ground now the rest is trial and error. When you finally get it connected write down the wiring so you can have it at a future date.
2answers
Wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
5helpful
Turner Rk 56 mic
Here is the wiring information for a Turner RK56. If the picture is too samll for you too see or it does not load up, email me at [email protected] with the subject as RK56 wiring diagram needed, and I will email it to you.
Dean Pitts
Rollin CBs
5helpful
The wires came of the plug of my Cobra Road King 58 mic. I need the wire diagram to put them back on.
if you have a cobra radio with four pin input and a turner road king 56 it goes like this. pin one shield and red wire,pin 2 white,pin 3 blue,pin 4 black and tape up the yellow wire it isn't used. the numbers should be on the plug if not look inside your jack on your radio. hope this helped
4helpful
Wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
