SOURCE: The Keurig is heating up the water, yet is does
So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
--snapshot4
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
My Keurig is not releasing enough water to brew anything no matter what level I select. Only about 1/2 a cup comes out.
After the pod is put into place and I push the button to fill, it makes a funny noise then shuts off. Sounds like something to do with the water flow.
keurig single beverage
Used a generic Kcup replacement. Cup fell down into holder (outer cup holder removed). Had to fish it out, but now the dispenser won't close properly; seems to be unhinged.
on brew function liquid will not go into cup.
kEURIG WATER LEVEL BROKEN
