SATA HDD is working with the other motherboard..... but this motherboard [ asus k8v-mx ] is not supported.... then how to solve the problem, how download the SATA drivers and how to update the bios.
As far as I can remember, the VIA VT8237R southbridge used on this board has a bug, causing it not to recognize SATA II drives.
You may be able to configure your hard drive to use the slower SATA 150 mode (1.5 GBit/s or 150MB/s) by setting a jumper on the drive. Unfortunately, this is not supported by all models - check the jumper description on the drive.
If the drive doesn't offer this feature, you might consider adding a SATA controller like this one (you may be able to find better and cheaper controller cards at your local computer store).
there are 4 different k8v motherboard types, you didnt say which variant?
but you shouldnt need any 3rd party drivers, either the one built into the cmos, or the ones that are on the cd rom that comes with the motherboard should work fine with win2003.
they have always been fine on my installs, just ignore the question on the initial setup, its only asking incase you need to use one, you dont have to.
