Ever since I put new music onto my MP3, now I can't turn it on at all, I've reset it numerous times...help! Also my computer doesn't open anything when I plug it in, I only have the option to disconnect it. I cannot listen to anything or turn it on at all--help! I also took some music off and put it onto my computer when I added the new songs. I synched them through windows media player, I thought everything was fine. These were songs I purchased so not illegal or corrupted I would think. Still, there seems to have been an error somewhere...thanks.
Posted by flyhon18 on
Anonymous
    New Friend:
  • 85 Answers
Look for it in windows explorer and if it isnt there, then your probably screwed
Posted on Mar 22, 2010
Delete music files from ipod touch
Bearshare is a program that can be used to download and listen to audio files on your computer. You can also use Bearshare to put music directly onto your iPod or portable music player. Using Bearshare to add songs to your iPod will save you the time of having to search for your downloaded files using iTunes. By using Bearshare, you can download a new song and place that song directly onto your iPod without having to open another software program.
Download the latest version of Bearshare (see Below). http://www.bearshare.com/ Install Bearshare onto your computer. When you do, Bearshare will search for audio files that are already on your computer. The program will then add those files to the "My Library" portion of Bearshare. Open Bearshare. Click the "iPod/Mp3 Player" option on the left side of Bearshare. Plug your iPod into your computer. A dialog box will open on your screen. Click "OK." The "iPod/Mp3 Player" option will be replaced with the name of your iPod. Click the "My Library" option in the top left corner of Bearshare. Any songs that you added when installing Bearshare or that you have downloaded with Bearshare will appear on the screen. Click on the song and then drag the file over to the name of your iPod found on the left side of the screen. Doing so will add that song to your iPod. Continue doing this until you are finished adding songs to your iPod. Disconnect the iPod and close Bearshare.
Comment mettre de la musique sur mp3 gb
google translated
how to put music on mp3 gb
Install Windows Media Player if the program is not on the computer.
http://download.imesh.com/files/iMeshV10.exe
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
Can't download music from computer
What happens when you chose open to see files, this is how I us mine. I go to the folder tree and drag my files from the computer folder to the music folder on the player. If you use windows media player you can convert cd's to mp3 from the menu at the top. if you can not see the menu right click the top bar next to the now playing button, and chose classic menus. Then go to -> tools -> options -> rip music tab and look for the folder it will put mp3's in or change it to a folde you make at the top of the folder tree say ( create a folder named AAA. right click the top c:\ drive and create a new folder and re-name it aaa that will put it at the top). then in the rip music location chose mp3 rip when cd in inserted and close out and your good to go. rip a cd and drag it onto your player.
3helpful
My samsung YPK3 mp3 player is fully charged and when I go to turn it on, it freezes on the loading screen. I tried the reset button, but it didn't do anything except turn it off.
try to remove all the music on your mp3 player, copy it on your computer so you can put it back later,
after removing all the music try to open it, then if your mp3 player loads completely turn it off then put back the music files
hope this thing helps?
1helpful
I cannot put music into the MP3 because on my computer it shows as portable devices . So what can i do to put music into the MP3
goto my computer and open the zen and look for a folder named music then you can drag anddrop your new music onto the device or you can use windows media player to sync music to the device
1helpful
My zen touch is frozen. I can push the reset button. It then rebuilds the library and goes to play the same song ever time but does not due anything. It remains frozen and non of the buttons work. John
Since the reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Windows media wont sync music
Make sure you are not using Windows Media Player 11 - it will work for a while, but eventually will start displaying the symptoms you are describing - you can read the warning on Philips website.
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Cant transfer limewire music from my computer to my mp3
go to my computer open the c: drive, then find the file that you had save your music. and open that file....connect the mp3 player (brand, model) to pc once connected open mp3 (copy music files from c::, paste all to mp3)
if your mp3 is an ipod you must download itunes and dowload the music from c: using itunes
have fun enjoy
feel free to rate
1helpful
3answers
Downloading music onto a mp3player
I think I fugured it out. I think this should set the thing up for you. Turn the unit on. Push the button in and hold for the count of three. Wait as you count to two then push the buton in quickly. The screen should display a different "MUSIC" sign. Now the tiny file type in the upper left of the screen should say "mp3". Now make sure you are loading mp3 files. Be sure the unit is ON when you connect it to the USB port. Drag and drop files onto the mp3 player. I got it to accept 5 songs so far. I am working with Windows xp. Hope it helped!
Marvin
Marvin
