You can buy a used DirecTV with Tivo. You probably had a Hughes SD-DVR40 or SD-DVR80 before. The used model needs to be transferable to your account (which means it can't be leased, it has to have no outstanding charges on the previous account, etc). And you have to buy a new DirecTV card.
If you are in the San Francisco Bay Area or in San Jose, write to [email protected] and they should be able to help you out.
if the remote is RC23, the tivo codes are 01442 & 01142. If you
actually have a Rc16, then you can only control the tivo partially with
code 20618 on either AV1 or AV2 device slots.
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
I've had my series 2 Tivo for about 2 1/2 years and never found the correct codes for it. I think it works off of a list of TVs manufactures about 3 years ago.
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
