If the yellow ink is not printing here's what you
can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to
select Test Print, then select Print Quality press OK and press
Black or Color START. Check all the colors including the black & check if
there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select
cleaning press ok
3. Press the up or down arrow key to select Color press ok and press
Black Start.
*After the cleaning process the printer will ask you if the quality is
OK, press up or down to select yes or no, and it will ask you whether black or
color is ok, once you have selected you're answer press Black or Color START to
print another test page. Compare the 1st and 2nd test page if it's
improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
If the cyan or the blue ink is printing out in purple here's what you
can do:
cleaning press ok
Black Start.
Hope this helps Please rate if it worked Thanks!
