RCA F27252GY 27" TV Logo
Posted on Mar 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have sound but not picture when I play vcr. I
On the colortrak xs stereo commercial skip RCA TV I have sound but not picture when I play vcr. I have the tv set on channel 00 what should I do for picture?
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Mar 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093570
Points
9665
I believe that channel 00 switches the set to the A/V inputs on the rear panel. You may have a bad cable or loose connection. Make sure the RCA plugs are firmly in the jacks at both ends.
The trouble may also be in the VCR. Sound but no picture is often a symptom of dirty heads. Try using a wet-type cleaning cassette and see if that brings the picture back. Wet-type cleaners come with a bottle of cleaning fluid which you apply to the strip inside. It's much more effective than dry type cleaners.
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Was just given a 1995 RCA Remote Monitor XS Stereo Colortrak TV. Seems to work fine, but remote doesn't. Can change channels manually, but after about Channel 5, it skips most on the way up to 99. How...
Just about any One For All remote control will work with this unit and any other remote controlled devices you may have.
This sounds like when doing the channel scan the scan was interrupted and therefore went from the channels it had already found to the ones that were at the high end of the register. Also, when you are in the setting menu, you need to specify the input as either cable or antenna, preferably cable, which will also scan each channel from 2 through 125. Please let me know if there is more information you would like and I hope you have found this helpful.
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
4helpful
RCA Colortrak Stereo Monitor won't play DVD/Nintendo
The way you describe having your TV/DVD connected you wont see the picture in the regular channel line-up.
You will have to tell the TV to to switch to the video input. This is usually done by navigating the menu to the "input" and selecting video 1, video 2 etc
Failing that try changing to channel 00 ( just type 00 in remote)
Some sets will allow you to type in 02 and then hit the channel down button on the remote.
If you have the user manual it will give you the exact steps you need to take.
12helpful
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
HELP WITH TV
check your fuse on your circuit bord
78helpful
9answers
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
1helpful
2answers
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
