Question about Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a problem with my car speaker/tweeter
Hi, i own a 2009 mitsubishi colt and there is a problem with my car audio system. I have a jvc headunit (4x50w), with edge front and rear 13 cm component speakers (70w rms), i run a combined 10 inch edge subwoofer and amplifier in the boot.
My system sounds fine when i have the volume at 18 however this is far too quiet even for classic fm especially with road noise etc, Past 18 vol i hear a distortion like sound from the front left tweeter or possibly front left speaker, the speakers are new and ive just had them fitted. The wierd thing is when i select the right only channel via my head unit i can have the sound past 25 which is really loud, even for my liking. but when put back to normal (bass 0, treb 0, and channel set to centre or at 0) the distortion type sound appears again.
Any help would be much appreciated. thanks tom c
Posted by tomcinthehou on
saffajay
    New Friend:
  • 49 Answers
Sounds like you have the ground and live possibly the other way around from the head unit to the speakers. The reason for you hearing it from both the tweeter and the speaker is that the tweeter is connected in parallel to the speaker.
Swap the wiring and try it.
Posted on Mar 21, 2010
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
May 18, 2016 | Dodge Cars & Trucks
Connect JVC MX-GT88 speakers to a differant reciever
If it has a bi-amp, you can connect the speakers to it. By the amplifier, if it's a stereo with bi-amp, be sure that it has at least 400 watts and up in order for the speakers to turn out great, if a receiver like a integrated amplifier, it may have like 2-10 connections, you can connect the speakers all together if it has more than 3 connections, if below 3, you may need to take the speakers apart and make it 3 way by connecting one wire to the tweeter, another wire from the tweeter to the main or mid speaker then one more wire from the main or mid speaker to the sub.
Feb 03, 2014 | JVC MX-GT88 CD Shelf System
How do preset a station on the jvc kdg230?
Hello... I am sorry you are having a problem. The correct procedure to store radio stations on this headunit is as follows:
- tune the headunit to the station you want to save
- press a the button 1-6 under the display that you want to store the station to and hold it for 2-3 seconds.
- it will store the station to this number
Hope this helps!!
20 year car audio/video installer
Bay manager
Mar 17, 2011 | JVC Car Audio & Video
JVC KD-R616 Car Audio Receiver wiring the speakers without the amp
The Front left and right speaker lines as well as the rear left and right speakers are marked on the output wires of the car stereo. These are marked and the positive line will be usually the wire with the same colour but with a line.
You can connect these individually to the speakers one by one... use the car harness if available.
Feb 04, 2011 | JVC Car Audio & Video
Car wiring diagram for JVC KD-R506 audio & speakers
this might help?
http://forums.justcommodores.com.au/car-audio/45638-jvc-headunit-wiring-diagram.html
Sep 11, 2010 | Car Audio & Video
Car audio
mike, this is a beautiful and perfect setup! if you dont have a headunit yet i know the #1 perfect one for you CLARION DRZ-9255 .http://www.clarion.com/us/en/products/2008/audio/source_units/cd/DRZ9255/us-en-product-pf_1172385113235.html i have owned every single piece of equipment that you have! my set up was the same exact way except i used focal utopia 33wx for my subs. but JL AUDIO are the masters at making the best subs for the money by far! i have owned every line of subs JL AUDIO has ever mad,my overall favorite. sean314 623 7054 cell
Sep 11, 2008 | Focal Utopia Audiom 6W Car Mid-Range
SP-UXV30 speakers
Offhand, the tweeter can be rated similarly to that of the woofer but not lower than 26 watts. I think your concern should also include the physical mounting and size since most branded units would be using proprietary components/parts and are not readily available.
Most electronics parts store would be carrying "generic" tweeters and "as per sample" would be your best basis. If I understand it right, **** Smith in Australia would be similar to Raon Stores in the Philippines or Akihabara in Japan.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | JVC FS-V30 CD Shelf System
Tweeter and door speakers to fit a Lexus EX 300 w/Levinson factory system
I found that they can hold up to 6 1/2" speakers and 2" tweeters. I'm not sure the specific mounting depth but i can almost assure you there wont be any 6 1/2" speakers that require a whole lotta space
Feb 22, 2008 | Cdt Audio Eurosport ES-100 Car Tweeter
Tweeters fading out
Turn on the HPF it will definatly clear up the sound.
Aug 07, 2006 | MB Quart DSD 216 Car Component System
Kicker Solo-Baric L7 S12L7 Car Subwoofer Logo
121 people viewed this question
Top Kicker Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Charles Tidwell
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
