These are both problems with you Temperature sensor and circuit.
I would check the sensor first. You should have close to 1100 ohms. If this checks out good and wiring looks good the relay is integrated into the board so you would need to replace the control. The info below was taken from www.appliancehelponline.com You can also find diagrams there to show you what these parts look like.
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control.
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
F5
Relay safety circuit failure
· Check oven temperature sensor circuit for intermittent high resistance.
· Check lock circuit
· Press Clear/Off and reprogram control. If code reappears, replace control
Note: If all above check OK the F5 code can be a result of a momentary loss of power (Do NOT replace control or lock, check lock circuit)
