Question about Onkyo HT510 Receiver
Selecting phono preamp for Onkyo HT-R510
Which pre-amp will work with a 1980s Marantz turntable and a Onkyo HT-R510? I've seen reference to a magnetic cartridge preamp, but am not sure that will work.
Posted by clunan on
Grubhead
  • Onkyo Master
  • 5,700 Answers
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Posted on Mar 21, 2010
Hi my new yamaha v373 amp needs a preamp to run a turntable so was going to use my previous onkyo txsv424 just wondering the best way to connect these two?
The turntable output cables go into the input of the magnetic cartridge preamp. The output ones go into an a tape in or aux on the Onkyo. I'm assuming that it doesn't have a input that says deck on it. Apart from getting some good quality interconnects between the devices it's a very simple thing to do.
Jun 01, 2014 | Technics SL-1210 Turntable
Onkyo TX 8020 Receiver sounds muffled. I have the Onkyo TX 80202 receiver and just bought the Audio Technica AT-LP120 turntable to connect to it. I have the turntable switch to "Phono" (so as to make use...
This sounds like a wiring problem. Perhaps a faulty earth connection inside the lead or the plugs to and from the turntable. Also check the connections to the cartridge, they can become loose or be connected wrong. Say a channel to the earth connection.
Apr 05, 2014 | Audio Players & Recorders
RIAA preamp
Just plug the turntable into your phone inputs. If there is next to no volume then you need a preamp because you have a magnetic (low output) cartridge. If you have a piezo type cartridge the output should be enough to drive the amplifier to rated output. Of your unit does not have a phono input I can tell you that it definitely does not have a preamp built in.
Mar 17, 2014 | Technics SA-DX930 Receiver
Can I connect a turntable with earth cable to an Onkyo CR515
yes you can but you will need a phono preamp such as the one found here.
http://www.turntableneedles.com/Phono-Pre-Amps_c_4.html
Hook the output of the preamp to Line 1 on the back of the CR515 and for simplest ground wire hookup, choose a preamp with a thumbscrew for the ground (earth) cable coming from your turntable.
Feb 16, 2013 | Onkyo Audio Players & Recorders
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
I recently aquired a used rotel rx102 stereo receiver and onkyo cp101 A turntable. I bought a new stylus needle for my turntable, and plugged the turntable into the phono jacks on the receiver and from...
If the receiver doesn't have a function specifically named PHONO, yes. Very few AVR's have phono preamps. They're not expensive. I'd check eBay.
Jul 05, 2010 | Nakamichi AV-7 Receiver
I have an old Hitachi HT-45 turntable that I just pulled out of the closet. I plug it into my amp and I have to turn it up all the way to hear anything???
It will need a pre-amp to connect it to your newer amp. The old style turntables normally used a magnetic cartridge that older receivers / amplifiers had a special phono input (which incorporated an internal pre-amp) to connect and hear at normal volume settings. Newer receivers / amplifiers normally do not have this type of phono input, thus the need for an external pre amp device.
Dec 29, 2009 | Audio Players & Recorders
Distorted sounds
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
May 09, 2009 | Audio Technica AT-PL120 Turntable
Onkyo HT510 Receiver Logo
394 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
