When parked with engine running the heat gauge goes to hot, but once you start drinving again it returns to the center of the gauge where it should be when driving.
The very first thing I would check would be if the battery cables are clean and tight. After that I'd lean towards a bad ignition switch. Do you have a ton of keys on your keyring? wiggle your key while its on to see if you can recreate the problem.
check that the wire to the temp sender unit has not fallen off and is shorting out on the head/block. The power comes from the ignition switch through the gauge down to the sender unit and because the sender is a temperature controlled resistance unit the voltage is very low and so the gauge reads cold . as the temperature heats up , the resistance is decreased and so the voltage is increased though the gauge and the needle reads higher.. Hench if the gauge goes directly to hot on start up the wire is shorting out or the sender unit is faulty.
This is a sign that the thermostat is sticking shut and then opening after the temp gets past a certain point. If the heat gauge goes to high and then drops down suddenly, this is the likely culprit and you need to replace the thermostat - again.
I have had them arrive from the parts store and be defective.
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Does the engine over heat or the gauge goes to hot. Really hot. Since the A/C is on , this puts an extra load on the engine. This is why the fans come on when the A/C is turned on. This is usually low speed fan mode. High speed doesn't come on untilll 220 to 230 degrees. Most vehicles. Cars don't over heat untill the gauge gets in the red, when it starts getting close is time to worry and stop. I guess the question to you would be, What does the temp gauge read?
you could have an air pocket in the cooling system that has to be burped. With a cold engine, park uphill and leave the radiator cap loose. Fill radiator and coolant reservoir. Start engine with cap loose and run at 1500 rpm until temp gauge reads normal. Feel if top radiator return hose from engine to radiator is hot. If yes, coolant is flowing and thermostat is open. If cold, thermostat is not staying closed until engine is hot.
