Question about Caterpillar (UB141344020) Wrist Watch
Broken glass of caterpillar watch
Do caterpillar watches has a service center in sharjah uae? can you send me the exact location by sending to my mail id: [email protected] thank you!!!
Posted by nerissenilo on
  • Anonymous Mar 23, 2014
    do caterpillar watches has service center in hyderabad
Anonymous
  • 714 Answers
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Posted on Mar 21, 2010
I have a Nautica Challenge NMX-100 that I need to find replacement screws for. These 8 tiny fillips head screws are located on the back of the metal watch casing. Can't find them anywhere on line or in...
You could take your watch to a local jeweler who would most likely have screws and probably give them to you for free. Or you could send a letter to the Nautica customer service department to request screws for your specific watch model. Here is the address. TG Service Center, PO BOX 2802 North Little Rock, AR 72115. This department routinely fixes Nautica watches and should most likely be able to send you screws for the back of your watch. If neither of those options work you could try buying the screws online on a website like this http://www.ofrei.com/page586.html If you are unsure you will find the proper sized screws, try taking a screw out and accurately measuring it. Google the some type of online screw warehouse, screw seller, or watch part store, and search for screws with the exact measurements of the screws on your model.
Jul 22, 2011 | Watches
Broken glass face on Ecclissi
Go to the shop or in the store where the watch bought, or in any center where you can find a watch similar to your girlfriend, im sure there's a service they offer for any watch they sell.
There's a possibility that they can fix again the broken glass or replace a new glass for it, they maybe have the same description and model to be replaced for that..
Visit the nearest watch center.
Feb 13, 2008 | Watches
Hello sir i have a casio spf 60d.when it runs in depth meter mode it suddenly blocks and does not operate or changes mode at all.An alarm that says RECOVER appears on the screen.after a while all of a...
I suspect there is water leaking in to the sensor unit circuit located just behind the sensor. The Casio service would change the sensor, and all the gaskets in the watch. Then do a water pressure test on the case and etc. to make sure no leaks. I do not think you can service this yourself. You would have to know exactly the parts to buy and have the tools, and the pressure chamber to verify the gasket seal performance.
You should send it to Casio with a copy of your complaint. Look up Casio on the Internet and choose your country. Go to support to find the service address and instructions of where to send the watch. If you email them it can take a few days till they respond. They will send you the specific instructions. Their service is terrific. I own a number of their high end watches. In fact I have one with them being serviced. Sometimes I have broken the glass because I am rough with my watches at times.
Feb 11, 2018 | Casio Sea Pathfinder Sports Watch...
How do I send watch in to get fixed?
Visit this link, then choose the country where you in. Choose repair and service, then find service location or contact us. For US they require to send it via UPS or insured parcel post. For more information kindly call the Casio service center first before sending it.
I hope this will help you.
Thank you for choosing fixya
Mar 03, 2011 | Casio Watches
I bought a hoggo boss watch from UAE 6 months before. But now it frequently stops. it is under warrenty. How can i get it repaired or replace. Now i am in indian and not planning to go back to UAE. Kindly...
send the watch to any of your friend or reletive through fedex or DHL etc and ask them to get it repaired for you. otherwise contact the dealers who sold you the watch and ask them what to do.but theres no such need of going through all this trouble, just get it repaired by a watch repair man i india.
Sep 28, 2010 | Hugo Boss Watches
Hi, My wife skagen watch crystal was broken when I took it to a battery replacement place. I have search on skagen to purchase only the crystal without having to send the watch to the US. Is there any...
I have had to replace more glasses in this watch than any other brand over the last two years - It is most definitely a design flaw. The truth is though that you will not need a genuine skagen part. Your local watch repair shop will be able to use a standard 1mm thick domed Mineral Glass manufactured by Sternkreuz for example. It should be fitted by a qualified watch repairer, but you should not need to send it to Skagen. Good luck
Sep 20, 2010 | Skagen 358SSSD Wristwatch
Clasp broken and needs repaired
The most trustworthy place to send your watch is the makers service center or take it to a makers authorized dealer.
To find the address, go to "boluva.com" and click on your area and then on "wittnauer" and then on either "service center" or "dealer locator".
Mar 02, 2010 | Watches
Watch face glass cover scratched where do i get a new one from. La coste law6200L
You can get from any experience watch maker work shop who do customized crystal or send your watch to La Coste Service center and if you are in chicago illinois
we do customized crystal at
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Sep 14, 2009 | Watches
The glass on my Jacque Lemans 1-1266 is broken.
Visit www.sternkreuz.de
Find somebody who speaks German as this site is in German.
Send request if they can supply or cut the glass for your watch.
BE WARNED: it can be very costly and you may need to send your watch to them for a proper measurments.
Then there is a mineral glass cutting service in Australia:
www.startlocal.com.au/wholesale/watchmakersequi/sa_adelaide/Steve_Martin_Mineral_Watch_Glass_Cutting_1847755.html - 12k - Cached - Similar pages
I don't know if there is a such a service in USA.
Good Luck
Dec 19, 2008 | Jacques Lemans 1029J Wrist Watch
Crack face glass
good after noon ! if you want to repair your watch can you bring here in my own watch center ,the exact address is ,MEDRANO WATCH and CELLPHONE CENTER located at b.laqui st.brgy.3 cuenca batangas philippines,thank you ! GOD BLESS !
Aug 28, 2008 | Skagen 105LTMXB Wrist Watch
Caterpillar (UB141344020) Wrist Watch Logo
396 people viewed this question
Top Caterpillar Watches Experts
Janelle Schoonover
Janelle Schoonover
Tom Chichester
Tom Lambert
Level 1 Expert
Are you a Caterpillar Watch Expert? Answer questions, earn points and help others
