Router connection fail
I can't connect to the wifi through the gigaset 504 router, everything seems to be working fine except for the internet and server. Help!
Posted by bella_meera on
Anonymous
    New Friend:
  • 121 Answers
Not sure what you mean is the problem connecting to the router with wifi or connecting the router to the internet?
Posted on Mar 21, 2010
I got new gigaset qv830 tablet can't connect to wifi & this is my first android
Android Tablet Wi-Fi Authentication Problem [Solved ...
www.tomshardware.com/.../45501-43-wifi-authe...
Tom's Hardware Guide
Oct 23, 2014 - 20 posts - ‎17 authors
I have a new Android Tablet, it seems to work okay, but I keep getting ... I am DETERMINED to get this tablet connected, though, and when I find ...
Gigaset 8" Quad Core 8GB WiFi Android Tablet w/Google ...
www.qvc.com/Gigaset-8-Quad-Core-8GB-WiFi-Android-Tablet-w...
QVC
Free
This holiday season, wrap up the gift that tops their list with this Gigaset QV830 tablet. Work and play--all from the same device.
Newsmy tablet T3 problem wifi connection - YouTube
? 3:48
https://www.youtube.com/watch?v=PSR9QU2eph8
Jul 31, 2012 - Uploaded by Jan Ochotnicky
Newsmy tablet T3 problem wifi connection. ... grey wifi/cant connect to google play error fix (root ...
[PDF]Gigaset QV830 Tablet - User Manual.pdf - liGo
Dec 26, 2015 | Tablets & eReaders
Gigaset 504 agu
power up your modem and connect to your computer directly with an LAN cable.
open your web browser (internet explorer)
type 192.168.254.254
and enter
you will be asking for administrator password which is normally "admin"
hope this answers your query
Jan 15, 2014 | Siemens Efficient Networks SpeedStream...
Hi there I have a gigaset 504 agu router and my
Its means that 11 people are using you're router. I would turn on WPA or WPA2 security on the router, and put a password on it, then use whats called MAC address filtering so it only allows you internet access. Also disable WPS if you can because it can be hacked easily.
Nov 03, 2013 | Siemens Efficient Networks SpeedStream...
How can i configure siemens gigaset 504 agu for bsnl broadband connection
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Search siemens gigaset 504
They have very easy setup instructions
http://etisalatsupport.blogspot.com/2012/07/siemens-gigaset-504-router.html
Save file for next time.
http://www.etisalat.ae/eportal/en/images/docs/userguides/modem&drivers/Setup-ADSL-Siemens504AGU.pdf
Oct 25, 2012 | Computers & Internet
I need to secure my gigaset 504 AGU, i put password on my router wifi but still i have a Enabled 50 clients,on my wireless network
you have put password for accessing your router( system config menu/router config menu) but not client WEP password, the router is still open access point( AP). configure a WEP key and then each/any of the client need to know this key/password to access internet via your router. good luck
Aug 14, 2011 | Computers & Internet
I have a siemens gigaset 504 AGU wirless router. I moved to a new apartment and changed my land line and internet company provider. Connected my router and wirless network was detected and connected...
Gigaset 504 AGU black color signal antenna . How to find (Host Name) and only showing there mac address ans ip address. i want see witch one using my net and we want fine friend computer name in my router .
Jul 01, 2011 | Siemens Efficient Networks SpeedStream...
My laptop doesn't detect the wifi connection by siemens gigaset 504 agu router...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 17, 2011 | Siemens Efficient Networks SpeedStream...
Siemens Gigaset 504 AGU router password and email adfdress forgot. How can open this usb modem. before it was working in uae etisalat.than
You need to made it to default factory reset by pressing a few seconds on the reset button in the bottom of the devices. When it restarts it will be looks as new and you should re configure the isp settings of your internet connection. That's all. Before you make reset, don't forget to save the configuration to your computer for the future. Because if it is not working when you made the reconfiguration, you can also install the configuration from this configuration file.
Apr 16, 2011 | Computers & Internet
Will gigaset 504 agu work with adsl & fiber optical as well... pls advice asap.. many thanks, vijay.
Yes this unit will work with a DSL and fiber optic connection for your internet connection.
Sep 01, 2010 | Computers & Internet
Siemens gigaset se587 error message 106
Look in Start - Connect to - Show all connections - If you have an Internet Gateway and the Internet connection shows disconnected - Double click the line and it will connect.
Now if I could only work out why it doesn't do this automatically ....
Also Use Internet Explorer to connect to http://192.168.1.1/ which should allow you to log into the router directly and set the log on details and logon password.
Regards
May 29, 2008 | Computers & Internet
Computers & Internet Logo
130 people viewed this question
Ekse
Marvin
Marvin
