Question about Adobe PageMaker Plus 6.5 for PC
When i try to launch setup this error message appears: setup requires _SETUP.DLL and _ISRES.DLL (located in _SETUP.LIB) please ensure these files are located with setup.exe.on the cd i find setup.dll and setup.lib but not isres.dll I have XP thank you paola
Posted by docdinik on
RAGHU
    Master:
    Sergeant:
  • 401 Answers
CHANGE SETUP CD
Posted on Mar 21, 2010
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
Nov 06, 2013 | Microsoft Windows 7 Home Premium for PC
A disk read error occurred
Click "Start" and "My Computer." Navigate to the "C" drive on your system and select the folder marked "i386." Find your "Winnt32.exe file and double-click it.
Press the "Enter" button.
Click "Launch Setup" when the Windows Setup page appears. When you click this choice and not the "Boot Legacy operating system" selection, you will not receive the "disk error" message any longer.
Adhere to the directions on your screen to finish the process of reinstallation.
hope this helps
Aug 12, 2012 | HP Compaq dx6100 PC Desktop
This is the error message I receive when I try to view siles: This program requires the file advrcntr2.dll, which was not found on this system. What do I have to do to rectify the problem?
Most advrcntr2.dll "not found" errors are due to issues with the Nero CD and DVD burning software program. The advrcntr2.dll DLL file is a file that must exist in the correct folder for Nero to burn CDs or DVDs.
Most often the "This program requires the file advrcntr2.dll, which was not found on this system." error, are caused when, for whatever reason, the advrcntr2.dll file is deleted or moved from its proper location.
The advrcntr2.dll file might go "missing" because it was accidentally deleted from the folder, because an anti-virus or other security program mistakenly removed it thinking it was a security threat, or perhaps when you last upgraded or reinstalled Nero.
Do not, under any circumstances, download the advrcntr2.dll file from any "DLL download site." There are several reasons that downloading DLLs from these sites are never a good idea. (If you've already downloaded advrcntr2.dll from one of those DLL download sites, remove it from wherever you copied it to and continue with the following steps).
Restart your computer. The advrcntr2.dll error might be a fluke and a simple restart could clear it up completely.
Record the serial number of your particular Nero installation. Follow these instructions on Nero's site for locating the serial number to your particular Nero version.
If you can't find your Nero serial number using Nero's instructions a product key finder program could help. (here is one that may help: http://download.cnet.com/Keyfinder-2010/3000-2094_4-75183881.html?tag=mncol;2 )
Uninstall Nero from your computer.
Be sure to uninstall using the Uninstall Nero link in the Nero program group (if available) or use the Programs or Add/Remove Programs utility in Control Panel.
Download the Nero General CleanTool utility ( http://www.nero.com/enu/tools-utilities.html ). Install and run this free program from Nero. This utility will ensure that Nero is 100% removed from your computer.
Restart your computer again, just to be safe.
Reinstall Nero from your original installation CD or downloaded file. Hopefully, this step should restore the advrcntr2.dll file.
Install the latest update to your Nero program if there is one available. There may have been certain issues in your original version of Nero that caused the advrcntr2.dll error you've been seeing.
Restart your computer again.
Run a virus/malware scan of your entire system if the Nero reinstallation steps don't resolve your issue. Some advrcntr2.dll issues can actually be related to hostile programs that masquerade as the advrcntr2.dll file.
Note: The advrcntr2.dll file should be located in the C:\Program Files\Common Files\Ahead\Lib folder. If you find the advrcntr2.dll file in the C:\Windows or C:\Windows\System32 folder, chances are it is not Nero's legitimate advrcntr2.dll file.
Hope this helps you.
Nov 27, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Spanish for everyone cd won't install. say's that Setup requires setup.dll and isres.dll. i have already tryed to install these files my self with no luck. Is this cd just not able to play on any computers...
Check the compatibility of the Disk/Application (it will be mentioned on the Disk cover or Box)
If your Operating System is not mentioned there then is in not compatible with the Operating System installed in your Computer.
Good Luck!!!!!!!!!!!!!!!!!
Sep 16, 2009 | The Learning Company Computers & Internet
Not able to access MS office
http://support.microsoft.com/kb/933347
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
Feb 28, 2009 | Microsoft Office Professional 2007 Full...
Msvcr80.dll file
Download it from
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr80
(Click the highlighted text "Click here to go to the download of msvcr80.dll"). Remember where you are downloading it. After the download has been completed, run Yahoo IM setup again, and when prompted for this DLL file, show program the path. When it recognizes the file, the setup should finish the installation (or asks for another DLL file. You can search and download them from the link above and use the same procedure)
Jan 16, 2009 | Microsoft Office Standard for PC
Unable to launch setup,CD installation problem
hi , please try to change the path while installing the s/w to any other drive for example c:\, e:\ etc
May 23, 2008 | Computers & Internet
Adobe PageMaker Plus 6.5 for PC Logo
354 people viewed this question
Top Adobe Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Sean Cole
Sean Cole
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
