Sansa fuze mp3 player software
plz give me link
The Fuzeplayer must NOT be connected to the computer before you install the software.
If this has happpened, you will need to remove the Fuse driver in Device Manager. (Inst for XP)
Go to My Computer->Right click and select Properties. In properties, select hardware and Device Manager.
With Device Manager open, plug in the Sansa Fuse player. Find the new driver that popped in.
(You can do and undo this several times until you are certain you have the right one.)
Right click the fuze driver and select 'Remove'.
Close all windows you opened.
Unplug the fuze player and do not connect it until the driver is reinstalled with the driver disk. When the software asks, plug it back in.
That should solve it.
Unsure? ask a knowledgable friend to help.
SOURCE: my computer does not detect my mp3 player sansa 4.0 gb
What i would recommend you to do is to uninstall the device and
reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware
then device manager...look for the sansa device..it usually located
under portable device..if its not showing there i would recommend you
to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download
the porting
kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
.Then check the mode of yuor device to make sure it sunder MTP not
msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media
player click on tools, options and click under privacy...clear the
history and caches...after you finish you can plug the device on the
back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
SOURCE: sansa fuze 8mb format and firmware update
go into device manager in computer management and uninstall the sansa driver. Restart the computer and plug it in again
SOURCE: 2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
SOURCE: My computer doesn't recognize my sansa fuze
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps!
