Question about Vivitar ViviCam 8025 Digital Camera
My vivitar camera is not getting charged.
How to charge a vivitar camera??
it is not getting charged after getting connects to my computer with the supplied cord....plz help
Posted by cpavan15 on
dennis bullard
    Brigadier General:
  • 4,090 Answers
1) Check that the battery is good It may have collapsed and need replacing.
2) try connecting with another cord to see if that is the problem.
3) take the battery and the cord to a camera outlesat to check integrity of both.
Please rate my help++++Thanks for using FIXYA
Posted on Mar 21, 2010
Camera, the charger cord broke, got a new one, not sure if it's charging cause it always shows the MSDC on the screen when I turn it on. What has happen to my camera? It is a Vivitar ViviCam x029
Are you charging it by connecting to a computer? The MSDC message says that the camera is connected to a computer. What happens if you disconnect it and then turn it on?
Oct 14, 2016 | Vivitar ViviCam X029
Why does MSDC , WITH BLUE SCREEN, appear WHILE CHARGING BATTERY?
You're charging by connecting to a computer's USB port? The MSDC simply indicates that the camera recognizes the connection to the computer. It should go away when you disconnect the camera from the computer.
Aug 26, 2014 | Vivitar ViviCam X029 Digital Camera
How I can charge my batteries on my Vivitar Vivicam 8025 if I don't have a battery charger?
Yes, you may charge the battery through the USB connection. Bear in mind that not all computer USB ports put out enough current to charge batteries. You may also use an AC-powered USB charger, such as used for some cell phones.
Dec 13, 2012 | Vivitar ViviCam 8025 Digital Camera
Hi I have the vivitar vivicam 8025 dont have my manual want to know how to charge my battery
First off, you can download a PDF version of the manual from the manufacturer at: http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
If you don't have a PDF viewer, you can download one from: http://www.foxitsoftware.com/pdf/reader/ (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods: A. Charge with USB cable Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
Apr 11, 2011 | Vivitar Cameras
I have the vivatar vivicam8025, how do you recharge it with the cable, I can't find the manual
Charge lithium battery
Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED will be off when charge full.
Mar 02, 2011 | Vivitar ViviCam 8025 Digital Camera
I have a vivitar 8025 viviCam touch screen for some reason since the first use I havent been abled to charge my camara since and have no way of getting a replacement walmart will not help me is there some...
You can try charging your camera in two different ways -
1) Remove the Lithium Ion Battery. Note - This might result in the loss of sample pictures. Now, place the battery back inside and close the Battery door. Connect the camera to your computer and see if MSDC appears on the screen.
2) Try connecting the Charger end to your camera and connect the other end to the Electric Outlet.
Note- The Red LED should be light on charging. It will turn off when the charge is complete.
If these do not work, you can try calling Vivitar. Since the Camera is brand new, I am sure they can help you with a replacement. Call them at this Toll Free Number - (877) 397-8200
Aug 30, 2010 | Vivitar ViviCam 8025 Digital Camera
How do you charge a Vivitar Camera?
According to the manual, your Vivicam 8025 is supplied with a charger, but the battery will also charge via the USB cable when the camera is connected to a computer. Need the manual? You can download/print it here:
http://vivitar.com/products/13/VC8025%20User%20Manual.pdf
Jan 01, 2010 | Vivitar ViviCam 8025 Digital Camera
Vivitar 8025 comes up msdc when i connect usb lead to my computer
It's supposed to do that, informing you that it's in mass storage mode. Once connected you control it from the computer, not the camera.
Nov 03, 2009 | Vivitar ViviCam 8025 Digital Camera
My Vivitar DVR840XHD don't recharge anymore when
The owners manual says "unit will not charge w/ usb connected to the computer." "charge only with the supplied adapter".
Sep 30, 2009 | Vivitar DVR-550 DV Camcorder
Vivitar ViviCam 8025 Digital Camera Logo
126 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Barbat Nae
Barbat Nae
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
