Washing Machines Logo
Posted on Mar 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Indesit WIXL143 stops part way through program
The machine was found to have stopped mid way through the program after the hot water has emptied but before the rinse, with the green lights still on, but nothing happening. Turning off and back on and resetting, by holding down the start button will allow you to re select the program but although the green lights show, nothing happens. After leaving off for a very long time (many hours), the machine will start to work again, but then stops at the same place. Later I tried the spin cycle (after many hours of leaving off) and at the end of the spin cycle the power light and the extra rinse light flash rapidly and cant be turned off except by turning off the power supply. After turning on again a program can be selected and the appropriate green lights come on, but no action then happens like before.
Danny
Level 2:
Sergeant:
  • Expert 160 Answers
  • Posted on Mar 21, 2010
Danny
Expert
Level 2:
Sergeant:
Answers
160
Questions
0
Helped
63217
Points
538
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Indesit dishwasher Dfg15b1 will stop during a cycle and the salt light flashes, the drying light stays on, and the start/pause button flashes.
I would check the water inlet flow rate is fast enough as these will time out if they can't get enough water fast enough.
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
1helpful
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
1helpful
Washer stop in middle of rinse cycle
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
2answers
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Dishwasher stopping mid program
sometimes machines stop to heat the water. does your machine ever start again?
if it does not start on its own, it could be a time issue, or a heater element issue. if it calls for heat and it never heats, it will never run.
if it ever drains, then the issue is not the pump. its a logic board.
good luck
mark
Permanent emptying on Indesit D61D Dishwasher
tilt it back the base is flooded have some towels to mop up the excess water then you are away again
Top Washing Machines Experts
john h
