Question about NorStar M7324 Telephone
Unable to change the time on the phone
When I follow the steps to log into system programming it does not acknowledge a password?
Posted by sonia_machad on
FLReader
    New Friend:
Nope
Posted on Oct 05, 2011
george peters
    President:
  • NorStar Master
  • 860 Answers
If feature ** 266344 with a password of 266344 didnt work you can also try feature ** 266344 with the password of 23646 or the password of 727587.
Also, on some versions you can try feature **8463(time) with the password of 23646.
Posted on Mar 21, 2010
Tip
How to Change or Remove Windows 7 Password?
Windows 7 allows you to create a strong Windows 7 password to protect your data on computer. Meanwhile it also provides you solution to change or remove Windows 7 password. So you are able to change Windows 7 password if you forgot Windows 7 password or intend to reset Windows 7 password for other reasons. Here are guides on how to remove or change Windows 7 password.
Solution 1: Change or remove Windows 7 password through Windows 7 control panel
If you can log on your computer with Windows 7 password, you can remove or change Windows 7 password easily through Windows 7 control panel.
To change Windows 7 password, please follow the steps:
Step 1: Click on Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Change your password.
Step 3: In the screen comes up, type your current password, the new password you would like to start using and a password hint. (password hint is optional)
Step 4: Click Change password button to confirm your Windows 7 password change.
Now your Windows 7 password has been changed, and you must use your new password to log on to Windows 7 from this point forward.
To remove Windows 7 password, it is also very simple. Just follow the below steps:
Step 1: Click Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Remove your password.
Step 3: Type your current Windows 7 password in the text box on the following screen.
Step 4: Click Remove Password button to confirm that you'd like to remove your Windows 7 password.
Now your Windows 7 account password is removed. And you will no longer need to log on your computer with Windows 7 password.
Solution 2: Remove Windows 7 password with Windows Login Recovery
If you are locked out of computer as you forgot all Windows 7 passwords, what should you do to remove or change Windows 7 password then? At that time, you need the help of Windows password recovery software to remove your lost or forgotten Windows 7 password. Windows password recovery software allows you to remove lost or forgotten Windows administrator password, standard user password on all popular Windows OS, including Windows 7. By burning a bootable CD/DVD or USB flash drive, you can easily regain to computer again.
Here are the steps to remove Windows 7 password with Windows Login Recovery Professional:
Step 1: Download Windows Login Recovery Professional and install it in any computer.
Step 2: Run the program and burn an ISO image file into the blank CD/DVD or USB flash drive.
Step 3: Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4: Remove Windows 7 password by following the instructions.
And now you can access to your computer without password. And you can easily remove or change Windows 7 password according to the steps in solution 1.
Of course, you can also change Windows 7 password if you have a password reset disk in advance. If you don't know how to create one, You could follow the guide of Microsoft's official website.
on Oct 14, 2010 | Computers & Internet
Reset log on password
If a user account needs to be reset, logon as the administrator or as a user with administrative access, and then follow these steps:
Click Start, point to Programs, click Control Panel, double-click Administrative Tools, and then double-click Computer Management.
Expand the Local Users And Groups object under System Tools, and then click the Users folder.
In the right pane, right-click the appropriate user object, and then click Set Password.
Type the appropriate password, and then click OK.
Click OK to acknowledge that the password change succeeded.
Close the Computer Management console and Administrative Tools windows.
The user can log on with the new password.
To Reset the Administrator's Password
Log on to the computer as a user with administrative privileges, and perform the steps
listed above for the Administrator account.
If the Administrator password needs to be reset, and there are no other users with administrative access, there is no way to recover the password and the operating system will need to be reinstalled.
or if you have not set a bios password
restart your computer you will see on your screen to press a certain key to enter bios usually the Delete or the F2 key
press and hold that key to enter set up BIOS where you can set or remove your password
this will differ depending on you computer and bios
hope this helps
Aug 03, 2012 | Dell OPTIPLEX GX60 Motherboard
How do I change the Date and Time displayed?
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
May 16, 2011 | Meridian M9316 Corded Phone
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
Forgot password to get into windows
When I forgot Lenovo Windows 8 password, I got Windows Password Recovery Tool Ultimate to support me make a password reset disk with USB and reset password efficiently!
Apr 30, 2010 | Computers & Internet
Im trying to change the clock on phone system. I
Hello, the default password is 1234. If it does not work with PROGRAM *# try with PROGRAM ** as described in the steps below:
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Feb 12, 2010 | Panasonic KX-T7633 Corded Phone
Log in to system programming T7316E
the log should be "setnna"(738662) with a password of config (266344) providing it hasn't been changed
Mar 30, 2009 | NorStar T7316E Corded Phone
Message Light Remains on
reset your system--Try the following steps--1) Feature 983, Log 120000, mBox, Change, enter mBox #(i.e.-24), hold Reset....
this changes current password to default password 0000 for mBox #(i.e.-24).
Next....
2)Feature 981, Other (do not enter password, instead go to "Log"), now enter the mBox # (i.e.-24) plus default password 0000 (i.e.-240000).
Next....
3) Follow voice prompt to change password (cannot start with #0), Re-enter new password (i.e.-246810), Say name clearly, Play name back, if satisfied then OK.
Next....
4)When accessing mBox, Feature 981, Other (shows "Log"), enter mBox # plus new password (i.e.-24246810), this is how you will now access your mBox.
Thanks
Nov 06, 2008 | NorStar T7316E Corded Phone
T7316E Telephone - Nortel Norstar Telephone System
When we purchased our Norstar T7316E system, the rep set up BASIC as our password.
Can you please send me a copy of your manual?
Oct 19, 2007 | NorStar Lands Phones
NorStar M7324 Telephone Logo
175 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
