Casio ClassPad 300 Calculator Logo
Posted on Mar 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to solve the below: int arcsin(x)^1/2/(1-X)^1/2 But I don't know where and how to enter the function.
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Mar 21, 2010
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4671821
Points
21595
Your expression is ambiguous: There is a function named int( which extracts the integer part of a numerical result. But there is nothing enlightening about it: int(25/3) gives 8 as result
Do you mean to calculate the integral?
Is it arc sin of square root of X or square root of arcsin(X)?
I am going to assume you want to calculate the indefinite integral of [arcsin (square root of X)]/(1-X)^(1/2)
In Main calculator screen tap the Down pointing arrow at the left of the tool bar (left of the Edit Menu). Select Settings>SetUp>Basic Format
I would like to solve the below: - 97e3e9a.jpg2ec4942.jpg
As you can see, the angle unit must be in Radians. Make sure that the Decimal calculation is unchecked, otherwise yoy will get a numerical result.
Press the keyboard key to enter your expression.
  1. Press the 2D keyboard
  2. Use the pen to tap the arrow close to the 0 to reveal the Integral template and tap it
  3. Tap the arrow again to reveal the fraction template.
  4. Tap it to insert it at the cursor position.
  5. Tap mth to open the mathematics tab
  6. At the bottom of the mth Tab press TRIG
  7. Tap the arc sine key (sin^-1) and insert it in the numerator of the fraction.
  8. Press the U-turn arrow at the bottom of the mth keyboard to exit the trigonometric functions.
  9. Tap the square root function to the right of the natural log, tap the variable x and right parenthesis, on physical or soft keyboards.
  10. Tap the down arrow to move cursor to the denominator of the integrand.
  11. Type in the denominator (square root of (1-x))
  12. Use the right arrow to move the cursor to main line, and one more tap to move cursor after the d, press the x key enter the differential.
The result is on the screen, but you have to scroll right to reveal it completely.
Here are some screen captures I would like to solve the below: - b1ad6c3.jpg in your quest.b1ad6c3.jpg6384179.jpg
I put in the arcsin (sin^-1)(128) and it gave me domain error. How would i re-write this expression to get the answer i need?
The arcsine function only takes arguments in the range of negative one to positive one. 128 is not in the domain of the arcsine function.
Could you post the problem you're trying to calculate?
Wrong answer produced in sin / cos problems?
5sin(x)+1 = 0 is the equation you want to solve?
so
5sin(x) = -1
sin(x) = -(1/5)
arcsin( sin(x) ) = arcsin( -(1/5) )
x = -.201 (radians)
x = -11.5369 (degrees)
3helpful
2answers
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
12helpful
2answers
How do I put cosecant, secant, and cotangent functions into my ti-84 plus?
By definition
  1. cosecant of X =1/sin(X), must not be confused with arc sine [sin^-1]
  2. secant of X =1/cos(X), must not be confused with arc cosine [cos^-1]
  3. cotangent of X =1/tan(X), must not be confused with arc tangent [tan^-1]
Because of these simple relations, calculator makers do not implement them with specific key sequences.
On this calculator, you have two ways to calculate one of these functions. EX cosecant of 37 degrees
  1. You enter 1 / [sin] 37 [ ) ] [ENTER] result is 1.661640141
  2. You enter [sin] [ ) ] 37 [ENTER] followed by [X^-1] to take the reciprocal of the previous answer. The [X^-1] key is the one just below [MATH].
A word of caution: secant cosecant and cotangent must not be confused with the inverse trigonometric functions arcsin, arccos, arctan
3helpful
I keep getting the wrong answers on my trig with the TI-84 when doing radians and angles. I put in sin( 3.06/5.17) and got .010 when the answer is 36.29 help.
Your result is clearly incorrect in view of the fact that the sine function ranges from -1 to 1. So it cannot be 36.29. For a moment I thought that maybe you wanted to calculate the arcsine but the results are not even close.
Here is a screen capture that shows you the correct results. You can see that I was right in assuming you were calculating the arcsine but not in radians. You are calculating it in degrees.
On the second line I calculated the arcsine of 3.06/5.17. Look at the top of the screen and you will see RAD. Thus the arcsine is in Radians. I multiplied it by 180/pi to convert the result to degrees, which apparently is what you want to obtain.
Here is what I suggest to you. Press [MODE]. Use the arrow to scroll to the third line, highlight Degree and press [ENTER]. Press [2nd][QUIT] to go to main calculator screen.
If your angles are in degrees, you should be working with degree as the angle unit, especially if you are calculating the inverse trigonometric functions.
Hope it helps.
Thank you for using FixYa.
2helpful
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
2helpful
How do you do arcsin on the TI-34II?
  1. Pressing [2nd] and [TRIG] displays a menu of all available trigonometric functions.
  2. The arcsine is represented as menu item [SIN^-1].
  3. Select the function from the menu, enter the value and press [=].
  4. A word of caution:
  • Before you calculate any inverse trigonometric function value, make sure the angle unit is correct. (Degree or radian).
1helpful
2answers
"Err: Domain"
I think you may find arcsin(x) is equivalent in older nomenclature to sin^-1 (x)...ie use the "2nd" and the SIN key instead of typing arcsin.
eg. arcsin(0.5) is 30 degrees is the same as sin^-1(0.5)
The ^-1 does not mean reciprocal, but "the angle whose sin is." Here the minus one indicates a kind of inverse operation. The word arcsin indicates that same inverse.
2helpful
Csc, sec functions
I have not yet seen a calculator that has a dedicated key for the cosecant , secant, nor cotangente functions, because they are directly connected with the sine, the cosine, and the tangente.
Cosecant (x) = 1/sin(x)
Secant (x) = 1/cos(x)
Cotangente(x) = 1/tan(x)
Do not confuse these functions with the inverse trigonometric functions, usually represented as
arccosine = arccos; on calculators cos^-1,
arcsine = arcsin ; on calculators sin^-1
arctangent= arctan ; on aclculators tan^-1
Hope it helps.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
