Question about Black & Decker PI400AB Power Inverter
Can i run my minn kota 30 trolling off my power box
Posted by pupa_1 on
Lynn Magnuson
    Problem Solver:
  • 10 Answers
Are you referring to an inverter by a "power box"? That term doesn't really describe the device. I'm going to assume it's an inverter you're talking about, a device that takes DC and turns it into AC. I'm not sure about that, but you should be able to plug a converter (turns AC into DC) of the right voltage, 12 to 14 volts DC into a generator on the boat and run it. I'm assuming the trolling motor runs off 12 volts DC and NOT gasoline. Be sure to check that before doing anything. Most do run off a large car or RV battery. Lead Acid Batteries for boats and cars produce 12.7 volts DC if they are in good shape and should have six cells (about 2volts per cell). 6 volt batteries are somewhat rare these days and have 3 two volt cells. Two of them in series will also power it.
Thanks for asking that question ... I like to fish also.
Lynn
Posted on Mar 22, 2010
WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
Can get replacement parts for my Minn Kota trolling motor FAQs
Apr 13, 2016 | Minn Kota Boating
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Trolling Motor specs
call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
Is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Jan 19, 2010 | Minn Kota Endura 30 Freshwater Transom...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Trolling Motor will not run
Hi!
For starters, here is a schematic:
Endura 30
Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
Best of luck!
Mike
Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
Black & Decker PI400AB Power Inverter Logo
190 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
