Big Button remote control have pre-programmed with 3 digit codes. There are no code for Insignia tV with it. Codes for this TV are:
0103 0189 0217 0135 0133 0116 0167 0456 0029
Anyway try a code search method. Some times, ti might help you.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
- Manually turn on the device (TV, VCR, etc.) to be controlled.
- Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks once, then stays on.
- Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
- Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
