Online user manual is here
http://www.cnet.com.tw/download/cwr-854.htm
If you goto page 37 it show the dhcp range .
Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11
try this
Start>run{vista/7 search box}>cmd>ipconfig /release
Start>run{vista/7 search box}>cmd>ipconfig /renew
see if that produces the correct info
thnx for the help, i already got it, just changed this 192.168.1.254 to 192.168.10.254... working fine now.. c",) thnx alot!!
your router and and default gateway should be the same address. Make sure your computer doesn't have a static ip address assigned to it.
2 Questions: 1) is the router conected to a DSL modem? 2) When you are in the router's web page, does the the router show as its Internet or WAN IP address as 192.168.1.*, or is it some other set of numbers? If it is some other set of numbers, to protect your privacy do not type the full set of numbers, just give the first 3 sets and then asterisks (for example: 24.13.231.*)
