Question about Minolta EP4000/5000 CS/PRO Copier
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
Posted by Manu Danha on
  • Tareq Bin Mostaq Mostaq
    If you are a technician,You take to determind problem on fuser unite. clean thermostate and press reset button copier motherboard.Your machine must be ok.
Anonymous
  • 1,110 Answers
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Posted on Mar 20, 2010
Display error co500. Please help?
Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Parts such as fuser lamp, thermistor and thermostat
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
3answers
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
3helpful
2answers
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
1helpful
Error code of C-50 showing in my CS/PRO Copier
C-05 Error code occurs on fuser unite.
When it display open back cover and press reset button.
Machine ready.If are not fix this problem.May be change or replace thermostat or lamp fuse.
1helpful
C05
Sir to fix will require you to take the rear panel off with the copier on. the upper rear panel once you have it off. Then find the circuit board on it will be a small black button, lower right side. press it. the machine will reset if it comes back your fusing unit (The HOT) part has a bad lamp thermistor, or thermosat. And will need replacing. The code will not clear by powering off then on. or by opening and closing front door.
2helpful
2answers
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
1helpful
My Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
2answers
5helpful
4answers
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to [email protected]
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Muzahura Frank
Mehandi Husain ...
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
