Video Cameras Logo
Question about Video Cameras
JVC Camcorder Tape door stuck
JVC Camcorder model GR AXM18U Tape door won't open. I used this camcorder maybe three or four times, and then the tape door stuck. I press the button, nothing. I cannot open it manually without forcing it, which I don't want to do. Any ideas? Thanks so much
Posted by vlmain on
Anonymous
  • 62 Answers
Michanical dis arrange inside the tape socket
Posted on Mar 20, 2010
What type of casette do i use for jvc gr-axm18u camcorder
JVC called it a C-CASSETTE or a compact VHS tape.
Tape stuck in Camcorder
check the tip in my profile
CAMCORDER WILL NOT PUSH IN A TAPE, STUCK HERE
Posted by delmas263 on Jan 02, 2009 I have the same problem, The camcorder will not take in the tape, stuck the tape holder will not go back in, notify me when you have a solution. Thanks
Tape stuck in cam corder
take a screw driver and open it up.
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
JVC GR-AXM18U Compact VHS Camcorder
perhaps you should turn off the camcorder, remove the battery, wait a minute, and then put it back in.
2helpful
2answers
JVC Compact Camcorder modle number GR-AXM18U
I had this same issue and it was driving me crazy. If you do not turn the camcorder on and hold the eject button, when it is trying to eject tap right in the middle of the tape (next to the eject button)  I had to do this twice before it opened but it worked. It tends to tighten the tape up and reset that error code message it is receiving internally.
2answers
Jvc-super vhsc-wont do anything
if there are no missing parts ? you will get it back in approximately 10 days . . . the repairs will not exceed $ 50 ( plus shipping to and from puerto rico - zip 00794 )
JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Open Questions:
0answers
SONY DCR-SR42 ACCESS RED LIGHT ON I bought a SONY DCR-SR42 from eBay in mint condition, I thought I could shoot on PRO Duo memory stick but I discovered you can only use it for photo and not for video so I looked for the USB cable to connect the internal HDD to my computer. At the moment I connected the camera, the LCD and the same camera turned off and even if I disconnected it, it won't turn on. I had to unplug the battery and the cable, I put back the battery and switched on the camera: a message appears on the screen just after the normal starting operation of "recover data", the message is "cannot recover data". The red light at the back of the camera with the ACCESS sign is always turned on, I tried to navigate the menus in every kind of way to access the hdd without succeeding, also tried to format it from the camera, also didn't work. I bought and replaced the HDD and the same error it's shown, I'm not able to format it or anything else and the same thing it's happening when I connect it to my computer to try access the disk and format it other ways. I discovered it' a kind of error, the E:31:00 as it appears flashing on the LCD, I red about this error on a blog called "videorecovery"(cannot post link) and I practically tried everything. I'm desperate about finding a solution to this problem but after buying the cable and a second not functioning HDD I wanna be sure of being effective so if anyone knows how I could solve this problem I'd really appreciate it.
Top Video Cameras Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
