I recently had to move my desk, unplug computer,monitor, etc. once i set everything up again, all colors on my monitor are distorted. can you tell me how to reset to defaults -- ie, give me the % that I should set for brightness, contrast, red, blue, green, etc. thanks
Hello there.
Hope this link will help ya Are Your Screen Colors Distorted or Off Here What to Do
Otherwise you can try an old trick and disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
It sounds like you're going to need a new VGA/DVI cable. (from PC to monitor)
I suggest you try another one, then post back here if it doesn't fix the problem.
Try looking at the Monitors Plug, Look directly into the Plug, you should see 15 small pins inside the plug.
Sometimes one or two of these pins get bent over and no longer makes contact. If you do see a pin than is not pointing straight out like the reset, the best thing to do is to use a small pair of needle nose pliers to gently straighten the pin. Be very careful becouse once a pin is bent it can break easily.
Its sounds like Bad Solder Connections,Have you moved recently,I know this doesn't sound technical but go up and slap it on the side and see if it acts up,Then you'll know its conns ttech
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
