Nintendo Wii Console Logo
Question about Nintendo Wii Console
Power will not come on at all a cable guy came to my house turned cable off to reset it my power went out and some sparks came out of some outlets next day my son went to play wii it would not come on. tried unplugging everything like it said to reset the power adapter still did not work.
Posted by lati626 on
lebeaujared
    New Friend:
  • 69 Answers
1. Try plugging something else into the socket to ensure the socket itself is working.
2. Changing the fuse in your Wii power adapter, blown fuses are very common and this could be it.
3. If number 2 doesn't work try and get a hold of a replacement power adapter as the problem could be a break in the wire.You can get a new adapter at this site NDSL games console, ds games console, NDSL games console_Video games Console_www.goldenbridge.hk
Posted on Mar 20, 2010
My canon mx300 will not turn on
This may sound silly, but make sure your cables are fully connected to the printer and your power cable is plugged in to the electrical outlet. Once, I received a phone call from a friend who was messing around with her printer for over an hour. She couldn't get it to power on. I went over to her house and immediately plugged it in... voila! It worked. ;)
My tv wont turn on
Look for power outlet and ensure there is power. Check TV on other power outlets. Ensure required voltage is there on the power outlet. Even then, if you notice that the TV does not work, it might be attended to by a skilled and qualifies service technician.
My wife pushed the ice dispencer then power went out tried plugging into other outlets yet nothing
Do the other outlets you plugged it into have power and something else plugged into them work such as a toaster /blender ect?? if all outlets in kitchen out their probably is a GFCI type outlet that has the reset button on it. Sometimes their in the kitchen or depending how the house was wired when built they could be in a bathroom or even garage. One outlet has that reset button but could have up to 6 outlets wired to it
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
2answers
WILL NOT TURN ON. GREEN LIGHT; TWO RED LIGHTS
check the projectors lamp.look like to need replace
My power to the house went out. now my printer
That outlet may have been blown from the power outage. Try changing the fuse in your fuse box or reset the breaker
1helpful
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
RCA HDTV 52 inch television
If a DVD and the onscreen menu looks sharp and problem free, I would say it's the cable box. Since you only reset it, I doubt it has anything to do with the cables unless you removed them and didn't insert them properly or tight enough. Try a power drain on the cable box:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on. This will also reset the cable box again, but draining the power can do wonders.
Top Nintendo Video Game Consoles & Games Experts
Aron
David Shaub
Joseph Hoffmann
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
