your capacitors are are bad open it up check the capacitors with any bulges in them and then go to radioshack and buy the capacitor with the same rating to replace. It is actually very simple. If it is under warranty still take it back
Sorry, but no. It seems that you got dead pixels on your screen. In this case would help only replacing the LCD, but its cost would be as big as the cost of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team at 1-239-768-7547 and ask for the recall issue Sony had repaired free of cost for such issues previously. Hence, contact the customer relations.
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
These issues are problems in the light engine (optics block)
the dots are called "starfield" and the geometric is "roadmap"
replacing the light engine will fix the issue. for awhile, sony was extending the warrany on the engine for these issues only, but that may have expired.
