SOURCE: whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
SOURCE: My american standard jacuzzi tub is pluged in but
check for power at plug in if power your vacume switch is probably out replace switch.
SOURCE: Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
SOURCE: some jets are clogged
the outer ring on the out side will unscrew, just be gentle and you may have to use a large pair of channel locks, plyers, but don't grip the plastic to hard so you don't scar the plastic
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
