Remove the clamps from the suction nozzle and pull out the roller. First of all check that both ball bearings are in order, so dust and hair free and run easily without too much play. Look carefully at the different depth marks on both sides and Make sure that they are reverted to the same setting marker.The belt is in the middle and with the square gray dial in front of the suction nozzle, you fully tighten the string so that the red color face of the top is visible when you look through the hole of the suction nozzle you see that the belt is tightened and in this Position may leave the belt for a short period of time, as always as soon as possible, ensure that the tension of the belt is off after each use.In short, in the tightened position, place the suction nozzle on the mounting bell at the bottom by lifting the motor housing slightly at the front or adjusting the depth adjustment as much as possible, just what you want, first place the suction nozzle on it and fix it with the clamp and then Couterclockwise turn the gray knob into the green mode.
Kirby Heritage II and Legend Vacuum Owner Video
