Washing machine wont work at all
Started a load to wash and it stopped in mid -cycle and is now COMPLETLY DEAD! Literally nothing works at all. It is a very old maytag washer, not sure the model number, and there is no power light on the washer to distinguish if anything is working at all. Please help with any info. My guess is that its the lid switch. COuld be motor but it doesnt even fill with water. maybe a timer, but again it wont even fill with water. PLease help, thanks.
Posted by jbm091000 on
Anonymous
  • 56 Answers
Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Posted on Mar 19, 2010
Anonymous
    Problem Solver:
  • 4 Answers
The answer above is from http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q3
Posted on Apr 04, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Washer stops mid cycle
Look under the machine cabinet for
a bag with the diagnostic manual
Oct 16, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
My washing stopped working mid cycle. I checked
the timer is probably sticking (needs replacement) or lid safety switch stuck open. try restarting the load and if stops at the same place it is the timer unit, if it fills up with water and than stops - lid switch.
Mar 29, 2010 | Washing Machines
Washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
Stopped working in mid cycle
lid switch assemblie.its the part where if you open the washer lid all stops,its that part.you may buy it on line with you model and ser# or at a local appliance store. God bless ,tom
Jan 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore Oasis washing machine is completely dead
discconect power for about 10 minutes,, then plug it back in should fix if not call repair possible control board failure ,,,,,,
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
