Question about Vector 750-watt Power Inverter Power Inverters (VEC043B) 500-Watt Power Supply
When I switch the power on the inverter, it squeals briefly and then shuts down.
Posted by dja_us on
Anonymous
    Genius:
  • 1,027 Answers
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Posted on Mar 19, 2010
What does opp stand for on a motor master 3000 watt inverter
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
Nov 26, 2016 | Inverter Electronics - Others
2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
Emerson TV will not stay on.why?
Emerson tvs (LCD Models) are famous for the screen coming up briefly then going dark and shutting down its caused by the transformers on the inverter board. You can get the replacement Inverter/ power supply board from www.tvrepairworld.com
Mar 02, 2013 | Televison & Video
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
When I power up my monitor the display briefly flashes on - to the login screen - and then the display goes blank. If I use the power switch to turn the screen on and off the same thing happens - brief...
Open the monitor, look for blown capacitors and replace them. If problem persist, test the light bulbs and the inverter. If the inverter includes ceramic capacitor, replace it. If some of the bulbs does not do the flash - replace it. Check the transistors of the inverter. Replace if faulty.
Aug 07, 2010 | Dell Computers & Internet
Power going up and down
An incandescent lamp that is cold takes approximately 10 times the running current initially. The inverter MAY not be able to start the 500 watt lamp if its protection circuits sense the very low starting resistance of the lamp.
Test the inverter on some other device first.
Jul 26, 2009 | Coleman Cable Power Inverter PMP1200
Heart 2500 w charger inverter only shows shut down and will not start bateries are new why
if it does not start, the inverter control or power transistors that do the switching may be bad
Jun 05, 2009 | Xantrex Technology Heart Freedom 25...
When I switch on computer monitor fails to stay on .
change capacitors c10 and c11 on inverter board
Dec 15, 2008 | Xerox XA7-192i 19" LCD Monitor
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Emerson EWL20S5C Shuts off after 10 secs
http://www.hypercubetech.com/EWL20S5_shutting_off_problem/index.html
Jan 12, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Vector 750-watt Power Inverter Power Inverters (VEC043B) 500-Watt Power Supply Logo
144 people viewed this question
Top Vector Computers & Internet Experts
efs_perpends
efs_perpends
Tom Chichester
Are you a Vector Computer and Internet Expert? Answer questions, earn points and help others
