Check all the connections to the MAF sensor, check the sensor for dirt and debris, clean the sensor with a spray cleaner like brake cleaner, check for vacuum leaks, Replace the MAF sensor.
Assuming you have an automatic transmission, I would check the transmission fluid level. If low, you need to identify where the fluid is leaking. Probable locations are transmission pan, or the cooler lines to the radiator.
If this has only begun to happen your transmission will probably be ok. If it has been happening for a while then you will probably be looking for a new transmission.
There is also one other possibility. If the check engine light is on and the codes read something in the area of "transmission control solenoid" or "shift solenoid" then you will need to have those replaced.
Please restore the factory settings by pressing *#7370# it will ask for your security code (default 12345) enter it and proceed. Phone will restart. It will take a while to restore settings so please be patient. Once restored your phone's bluetooth should work just fine.
Important: Make sure phone's battery is fully charged (or keep the charger plugged in) before performing the above operation.
Try replacing memory chip with a working one and see if it works. If not then your phone card slot may have a problem so you can contact a nearest phone technician for assistance.
what security code have you put on it is it a phone lock code ie when you turn it off then back on it asks for a code or have you changed another security code
when i try to switch the phone on it comes up memory full.. phone start
up promblem on screen.the phone wont switch on. i want to save all my
info on the phne or access it. can u help plse..
Answer:- If It doesn't swithes on then there is no way to save any info. U must erase its all data by pressing
[calling key(green key)3 * and switch it on u must press all 4 of them
at once and remember ur battery must be charged enough to run it
atleast 20 minutes and it will show formatting and after a few minutes
it will start and ask for date & time
