Question about Keurig Elite B40 Coffee Maker
Power turns off randomly - Keurig Elite B40 Coffee Maker
Posted by deborah_patt on
Fathi Elmahdi
  • 1,871 Answers
Hello :
First check the power cord ! If it's OK , then you need to check if the fuses are OK also . If fuses are OK , then the problem is with the power PCB . Fuses are easy to be replaced . Power PCB is a bit complicated . You need to take your coffee maker to a repair shop for that .
good luck .
rate please !
Posted on Mar 19, 2010
Zanussi fridge freezer
Sounds like a bad solder joint causing intermittent power issues...
Jun 19, 2016 | Zanussi Refrigerators
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
Casio - 120 Turns itself off randomly
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
Jan 06, 2014 | Casio Music
Power indicator light is on but will not run, fan turns off and on randomly
I would suspect a PSU, how old is the machine? Check the CMOS battery, reseat the Memory mods.
Dec 25, 2012 | Acer Veriton M661 PC Desktop
Power is erratic. Shuts off randomly.
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Apr 06, 2010 | Sony VAIO VGN-T350P/T Notebook
Random turn off
it could possibly be a faulty power cord. try plugging your cable to a different power source if that doesnt work than try replacing the power supply cable.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Screen only turns on randomly during start up, led lights are lit, laptop sounds like it wants to turn on and stops, then tries again, then stops. Problem happens about 9 out of 10 start ups, and when it...
remove battery, press and hold power button for 5 seconds, then wait 5 minutes, put battery back in securely and try again. If it powers on, try and look at the power meter to see if it is registering the power supply. You could have faulty memory chip or faulty power supply
Nov 30, 2009 | HP Pavilion dv6000z Notebook
Truck randomly looses all power and doesn't idle
check fuel preasure regulator function using a vaccum pump
Jul 07, 2009 | 2000 Chevrolet Silverado
Set goes turns on and off randomly
Use the remote to go through the menus, there are many TVs’ that have a remote on function that will turn on the device with a power up. So, if you have any power interruption no matter how short, the device will turn on. Go through the menus and turn this function off.
Jan 23, 2009 | Televison & Video
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Keurig Elite B40 Coffee Maker Logo
571 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Vincent G
Vincent G
Colin Stickland
Colin Stickland
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
