Question about D-Link (DI-784) Wireless Router
D-link DIR 635. Upload speed is sometimes very low
I use a D-Link DIR-635 router. My upload speed is sometimes very low, most significant on Windows XP computers. (downlaod always OK). It is not a modem problem.
I use USB Canon LBP5000 printer connected to main compupter. Sometimes printing from other computers takes very long. Could this be a router problem?
Posted by math_g on
electronic & computer repair& servicre
  • 12,061 Answers
No it is NOT, most probably a spooling problem, or may need more RAM. some jobs depending on size and type can take a long time to spool, and print, try setting print quality lower too this helps.
Posted on Mar 19, 2010
Slow upload
Usually uploading speed will be slow in any type of connection.It is default.Uploading speed will be 1/4 fourth of downloading speed.So uploading speed won't increase more than that.If you fee your internet uploading speed is very slow,it is because of internet traffic.Try using internet in non traffic time.Also try to avoid many downloads at same.You can use latest browser for browsing.To check internet speed visit the site Scanmyspeed.com
Aug 20, 2013 | D-Link DIR-615 Wireless Router
When i download something form internet my speed goes down and restarts the rooter i have a d-link dir-635 with latest firmwere what is the problem ??? thankyou.
sorry i have not got a solution to your problem but i have the same router but i do not have a installation cd for it, have u still got yours?? email me if u have at [email protected] thankyou.
Jun 20, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
How can i change the password of my D-link DIR-635 router
To change any settings on the router, you will need to access the router set up.
Do you have any computer connected to the router with the cable?
If not then you will need connect the computer to the router.
open the setup page and change the settings.
Click Here for step by step instruction
Dec 05, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
I have the same problem with a dlink dir 825
hi,
I believe the firmware of the router is outdated. Plz try to upload the firmware for ur router from d-link router website.
thanx and regards
sukhiii
Jul 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot upload pictures to an ftp site
You would open ports 20 and 21, and that would allow FTP transfer in passive mode. (Windows DOS FTP client does NOT do passive mode - so don't use that for testing)
Mar 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Mar 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Upload speed
Enable UPnP....UPnP can help make sure NAT works correctly for Xbox LIVE. Usually, this can be set on your router configuration web page, which is supplied by your router manufacturer. And, make sure UDP is open for the Xbox ports your using.
Jan 29, 2009 | D-Link DIR-625 (790069292637) Wireless...
I can not log in Call 1-8O5-225-669O We are 24 Hour Available Call Now To Customer Service
log on to your router > click on status> in left pane click on logs. Older logs are deleted when memory full.
If running the SYSlog utility you can save to a folder on your computer. You name the folder.
Link to manual:
ftp://ftp.dlink.co.uk/dir_products/dir-635/DIR-635_manual_10.pdf
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link (DI-784) Wireless Router Logo
589 people viewed this question
Top D-Link Computers & Internet Experts
Mike
RockTheHood
k24674
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
