Question about Canon Office Equipment & Supplies
I have a photocopier IR2016,and it shows the error E0002!
Posted by yaniaks peter on
Anonymous
  • 114 Answers
Its a fixing unit temperature insufficient rise in heat.
possible bad heater lamp or bad thermistor or bad themofuse
Posted on Mar 22, 2010
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How do I correct my photocopier machine Canon iR2016 with SYSTEM ERROR E007
Hi !
The error is caused when the fixing film is worn , it has a white patch that needs to be seen by the patch sensor , replacing the film will resolve the problem , as you can see on the picture below,
Oct 08, 2015 | Canon Office Equipment & Supplies
Canon ir2016 show
PROBLEM WITH CANON 1R 2016 PHOTOCOPIER
SHOWING ADJUSTING WAITING FOR SCAN
PLEASE HELP ME HOW TO FIX THIS
Mar 22, 2012 | Canon iR 2016i Black and White Copier
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Cannot Photocopier Model - IR2016. Shows Error No.007. Please advise for troubleshooting
have to uninstall the program and again at dell.com Reintal there will need to find the driver
Oct 17, 2010 | Office Equipment & Supplies
How can i solve error canon Ir2016 (download standby) error
Hi, you need to upgrade firmware from start. Download standby is message that appears when system is colapsed and when you want to upgrade firmware from service mode.
Jun 11, 2010 | Canon iR 2016i Black and White Copier
ERR E0000 & E0002
There are 3 step to repair e0002 error
If you got e0002 error then there is a 94% chance that your computer has registry problems. To repair e0002 error you need to follow the steps below:
* Step 1 - Download a e0002 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair e0002 error.
Here are the url of e0002 error repair tool:
http://www.fixerroreasy.com/ttfix-e0002_error-zz0005
Feb 13, 2010 | Canon ImageRUNNER 3570 Copier/Printer
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Oct 03, 2009 | Canon iR 2016i Black and White Copier
80 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
