Which plug did you change? "EP" stands for Extended Play. A VHS recorder has three speeds. EP is the slowest. A standard 2-hour tape will record for 2 hours at the highest speed (SP), 4 hours at the middle speed (SP) and 6 hours in EP. There is a trade off. The faster the tape moves past the recording/playback heads, the higher the picture quality and visa versa. So EP gives you long recording time at a cost in quality.
I doubt that the unit being in EP mode has anything to do with the cable. You did not say what brand and model recorder you have, but in general, the speed is adjusted with a switch on the front panel (older models) or via your remote control.
Are you asking how to change the record speed to extended play? This is usually given as a choice when programming a recording. You use your remote to scroll through various options on the input screen and you should find that you can choose between sp/ep/lp (standard, extended and long play)
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Refer to the "MENU SETTINGS" and "SYSTEM MENU" sections of the manual (pages 18 and 20 in my copy) for full details. If you need a manual, you can download one at http://books.jvc.com/Download/116492749/LYT1214-001C.pdf
Most VCR's have a default recording setting for recording speed or other settings. It's just a question of finding the right menu. Have a good look around the menus. However the VCR might default to SP after recording in EP, however the playback should switch to EP when playing.
Hi; I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen. harrisonmx3
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
sounds like it needs a good cleaning, you will notice this problem in sp first when needs cleaned. however if you had done this I would go over it again and if not then change the video head
