1997 Ford F150 Regular Cab Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door adjar warning light stays on. Dome and cargo light stays on.
Chris Weber
Level 2:
  • Expert 131 Answers
  • Posted on Mar 19, 2010
 Chris Weber
Expert
Level 2:
Answers
131
Questions
0
Helped
61022
Points
364
You need to remove the door ajar sensors from the doors and clean and lube them. You must remove the interior door panel then remove the door latch. Then twist the switch out of the latch to work on it.
The door adjar lights stay on, and the dome lights stay on when the doors are all shut.
One of the switches that gets pressed in by the closed door is bad.
I have a 2000 f250hd 2wd the dome light stays on
Remove or replace the relay for the interior lamps. Ford is notorius for having this problem
1helpful
3answers
How do I remove the door panel on a Ford F250 Supercab. I'm trying to find the switch for the ''doors adjar' light which won't go off and subsequently keeps my dome and outside bed light on and draws down...
the door adjar switch is the problem. the cargo light stays on until 35mph, as well as the overhead dome light. i just took the bulb out of the dome light and dont worry about the cargo light. it stays on for 30 min after the truck is turned off if the switch didnt trip properly. it shouldnt cause any problems as long as your batteries are good. i havent replaced the switch yet but it should be on the part of the door by the latch. get the replacement part and do a visual I.D. when you get the panel off. then replace it. the sensor is only 14$
04 EXPLORER DOME LIGHT STAYS ON, DOOR ADJAR LIGHT ON, DOOR JAMB SWITCHES WORKING PROPERLY.
At least one of your door ajar switches are sticking. Try spraying rust penetrant into the latches and open and close the doors several times. If they still stay on you will have to locate which latch it is by removing the door panels and disconnecting the switches.
1helpful
2answers
The rear cargo light won't turn off. This happened after I replaced a rear turn signal tail light bulb and a fuse for the horn. (These went out at the same time.) When the blinker light and horn were...
Hello! The instigator of this problem appears to be the the rear cargo lamp; Official name is rear dome light. You'll need a multimeter set on the X10 ohm scale to shoot this trouble. Leave the rear dome light bulb out. There are two switches involved; #1 the rear dome light on/off. #2 the right hand front door switch.
Pull the horn fuse out, remove the rear dome light cover, drop the rear dome light down to access the wiring and close all doors on the vehicle. Connect one lead of the ohm meter to the white wire and the other to body ground. If you read any resistance one or both of the two switches (dome light switch or right hand front door switch) is remaining closed when all doors are closed. Next disconnect the black lead from the dome light switch and see if reading changes to zero. If it does this is indicating that the dome light switch is defective. If it does not, disconnect the right hand door switch and take another reading at the same location. If you still measure any resistance, the black wire of the rear dome light is shorted to ground, if not then the right hand door switch is the culprit.
The reason the right hand door switch and not the left hand door switch is involved is the fact that opening the left front door would turn on the front dome light as well as the rear light. If both dome lights are staying on with all doors closed I would then involve both door switches in this test procedure. If your vehicle is a four door model then disconnect one door switch at a time while performing this test procedure.
The horn fuse also supplies power to the rear dome light, and I suspect the two events are related.
Guru..............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
3helpful
2answers
My cargo lamp on will not go out
Your courtesy fuse is blown. Look under the hood fusebox. There should be a fuse labeled CTSY (10amp). If blown, you have a hot wire touching bare metal.
4helpful
3answers
Cargo lamp on message stays on
Check under the hood, in the fusebox, for a fuse label ctsy (courtesy). It'll be over the driver side wheel. Replace it, if blows and, you have a wire touching bear metal somewhere. Good luck!
2helpful
1helpful
Open door lite stays on --we cannot lock the car with the remote alarm botton? 2000 ford taurus
You may have a bad door switch. The alarm is usually wired into the door adjar switch amongst other things. If the alarm system is being told that your door is still adjar due to a bad switch in the door jam then it's quite possible that the alarm system will not operate the locks if it thinks the door is adjar in which is also evident by the dome light staying on. Sounds like a switch. If not the switch then I would lean more towards the alarm system being responsible.
Good Luck. I hope this has at least narrowed down your search if not pinpointed it.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
