The HT630 scanner is a handheld barcode scanner, and an error message can occur for a number of reasons. Here are a few steps you can try to clear the error message on your scanner:
Check the user manual: The user manual for the scanner should have a list of error messages and the corresponding solutions. Look for the error message that you are seeing and follow the instructions provided to clear it.
Restart the scanner: Sometimes, simply restarting the scanner can clear an error message. To do this, turn off the scanner and then turn it back on again.
Check the connections: Make sure that the scanner is properly connected to the host device, such as a computer or a mobile device. Check the cable connections and ensure that they are securely connected.
Check the battery: Make sure that the scanner has enough battery power. If the battery is low, the scanner may display an error message. Charge the scanner or replace the battery if necessary.
Update the scanner firmware: Make sure that the scanner's firmware is up to date. Outdated firmware can cause errors and malfunctions. Contact the manufacturer for instructions on how to update the firmware.
Factory reset: If none of the above steps work, you can try performing a factory reset on the scanner. This will erase all the configurations and settings and will set the device to its original state. Check the user manual or contact the manufacturer for instructions on how to perform a factory reset.
If the error message persists after trying these steps, it's recommended to contact the manufacturer or a professional technician for further assistance.
It's worth to mention that, Each scanner has a specific error code, some error codes can only be cleared by the manufacturer, by sending the scanner to repair or by a firmware update.
It would help to know "exactly" what the error message states, such as "The USB Device Not Recognized" or something like that. Here are a couple of things to try in order to narrow down the problem source:
1. Try a different USB connection on the computer. If that one works, the problem is probably that other connection port.
2. If none of the ports work with the printer, try a different USB-powered device, such as a cell phone and charging cable. If it works, the problem lies with the printer/computer connection (more likely the printer).
3. If none of the USB ports work, the problem might be your USB port itself. Go to "Device Manager" (in Control Panel), then look for "Universal Serial Bus controllers." Check to see if any have a disabled symbol. Check under "Properties" that device status is: "This device is working properly." If not, try updating the drivers (under the "Driver" tab).
You must have your satnav registered with garmin to get the updates. If it's not registered connect it to your computer and go to www.garmin.com. Select your country from the drop-down list. Click on "Register your garmin device" and follow the prompts. You'll be asked to create a username and password. Keep them safe as you'll need them again when you want to update your maps.
To get the updates go to www.garmin.com and log into myGarmin. Click on myMaps. The maps on your satnav will be shown there. Beside the map name there will be a message stating either "No update available" or "Get Update" If it says Get Update connect your satnav to the computer, click on the message and follow the prompts.
I had same problem. I called Garmin customer service who connected me to a computer rep. Garmin hooks with your computer that you have your Garmin plugged into.They can upload the proper software in no time at all.
The rep told me that after I updated my Garmin I might have turned off the unit before it completed updating the new software. You need to wait until the screen with "Where to?" appears.
It works great now. Prepare to wait on hold for a while. I waited just over an hour on Monday, their busiest day.
1. Connect the camera to a diffrent USB port and try to download Pics.......
2. Goto My Computer Device Manager see if u find any yellow exclamation or question marks under Imaging Devices if yes right click on it click on update drivers choose to update the drivers from the CD and it should work if u don see any imaging devices that states that the USB cable is defective get it replaced................
Does it recognise the Nuvi? Are you connecting it through a usb Hub. Are the drivers for the nuvi installed properly? Usually there is a folder named USB, thats where the correct drivers reside, and that's where you tell the computer to look when it asks for the drivers.
