Dishes are never put in dishwasher with food particles. Wash and rinse ran as expected, however after we unloaded the dry dishes we noticed water in the bottom of the tub. No air gap in this installation, and drain hose through garbage disposal is clear. this happened once a year ago, but all the washed since have been completed, until yesterday.
Check the drain hose stub connection at the disposal for plugging. Lots of material flying around in there which could block the stub pipe. You might consider inserting a short section of drain pipe that has a built-in stub into the regular sink drain and plug the disposal stub. Also check the screen at the bottom of the lower spray arm assembly for plugging. Clean the screen in a mixture of hot water/detergent/white vinegar for an hour or so. That will remove hard water deposits from the screen as well as any food debris. The draining process is a timed event, so it depends on fairly rapid removal of the water. Hope some of this helps!
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
