My brand new Maytag Bravos electric dryer is showing the AF error code. Clothes will be hot but not dry and the blower doesn't seem to be working. The vent is clear and there is no lint anywhere.
If thats not it, then you nay have a faulty sensor.
AF
Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not obstructed.
F01 means that the main relay control board inside your control panel has failed and your control board would need to be replaced to fix the issue.
Apr. 18, 2014
Maytag Bravos 7.0 Cu. Ft. Electric Dryer F73 - Questions ...
www.fixya.com/search/p688923-maytag_bravos_7_0_cu_ft.../f73 have a bravo dryer , wont start shows error code f73 ? lights come on but dryer ... I think there was an F73 or F93 error message but we did not write it down.
Maytag Dryer and FE code means power source "Frequency Error". Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts Hope this helps (remember to rate and comment this answer).
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
