theres a couple of version of this router
http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3
I'm using the manual from here
http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
you should be able to loginto the router and setup the wireless -
if you are not able to login - you may need to do a factory reset and then login using the default settings and reset up
a useful tool for detecting wireless networks is this
http://www.xirrus.com/library/wifitools.php
you can use this on the PC to see if the wireless is broadcasting, if you can detect it on the PC
Testimonial: "Thank you very much, sounds like a plan. I will try the suggested data asap. Again, thank you so very much. K"
