Question about Jenn-Air Ovens
I have a problem with my jenn-air oven model w256w. On the touch appear F8 alarm. What can I do?
Posted by vhgovea on
ejasperse
  • 189 Answers
Hello- The code described- F8 indicates a failure in the clock, or control that operates oven. There is no simple 'fix' to this problem. "Self- clean" is the usual cause of board failure. Find a good tech to check it out on site Get an estimate before repair, and remember- Avoid "self-destruct" feature in the future. --Please reply if this info helps- have more if needed.  Thanks- Ed
Posted on Mar 18, 2010
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Replace doors on jenn air oven with stainless
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Jun 19, 2008 | Ovens
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn- Air Model W256W
hi Randy
first try to unplug the unit, let it sit for a while then plug it back in, if you still get the code look on the back of the unit there should be an envelope that has a paper inside it, that paper should list what the code means.
Apr 01, 2008 | Ovens
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn air oven
I had the same problem. I went to the manual and it is very easy to fix. The oven control lockout was somehow set. To cnacel it just press the Cook Time and the Stop Time buttons at the same time for 4 seconds. The "off' will appear briefly and then disappear. It worked for me. Good Luck!
Aug 20, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
201 people viewed this question
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
