Question about Dryers
Just replaces heating element in GE dryer. Dried one load but does not work, now. Light works, so it has power. Suggestions?
Posted by dcsombb on
marka19
    President:
  • 1,430 Answers
I would check the thermal fuse or thermostat. If the thermal fuse is blown check for obstructions in your vent then replace. For a video on testing these components go to www.appliancehelponline.com/servicemanual.html scroll down to troubleshooting an electric dryer.
Posted on Mar 18, 2010
Anonymous
  • 534 Answers
Check the high limit switch in the casing of the heating element itself. The high limit switch is a safety switch to prevent the heating coils from over heating past a set temp. point preventing a fire. This switch may have burnt out as soon as you replaced the coil
Dave
I HAVE kENMORE GAS DRYER SERIES 80. last week dryer would heat for a minute then go out. Dryer would spin with no heat. Wnt to appliance store told me to change heater fillaments that one was bad after...
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 17, 2011 | Dryers
Hello, I have Kenmosre 90 series dryer. Did a load ealier today, and it was fine. Went back to put another load in and realised NO heat was on, absolutley no heat in the dryer, the air inside is room...
you may need a heating element. You can go to your locale appliance store and buy the element & install it yourself . Just make sure you take All your dryer info, (etc; the dryer model, make, yr & the serial # ) this info is easy to find, its located inside the dryer door. Just call around your locale area and ask them how much it is for the heating element, for your dryer. It should be rather cheap compared to the cost of Kenmore appliance company coming out to fix it for you. The heating element is rather easy to install. I have installed a few in my own dryers and in my hot water heater.
Thank you.
Sincerely,
cat2868
Jan 28, 2011 | Kenmore 62802 Electric Dryer
Dryer not working
check to see if your vents are clogged its the num. 1 reason. if they are most likely your thermal fuse blew out, have it replaced. Another reason is your heating element went bad. Check for continuity on both items.
Apr 16, 2010 | Whirlpool LER4634J Electric Dryer
My GE dryer just turned off and won't come back on. we took the front off and cleaned it out and it worked again for 2 loads of clothes, then it stopped again. the coils looked good...my husband says it is...
Wait an hour and then try it again. If it works, but then trips the breaker again, your heating element could be drawing too much power and overloading the breaker. The solution would be to replace the heating element. First weigh the cost of a new one against removing the heating element and asking a technician to look at it.
Dec 16, 2009 | Dryers
I HAVE A GE DRYER THAT WAS WORKING FINE ONE LOAD THEN STOPPED HEATING UP ON THE NEXT LOAS.IT TURNS FINE BUT NO HEAT
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
GE DNXR47GW1WW Dryer is extremely slow to dry clothes (takes over 2 hours per load). The dryer does heat. Any suggestions?
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective. (if this is a gas dryer, please disregard this statement)***
Jun 16, 2009 | GE Dryers
All the vents have been cleared inside and outside, however, the dryer doesn't heat up, cold air blows and clothes don't get dried. Whirlpool LGR8620PG0
Sounds like your heating elements are not working. I would check to see if you have power to them first. To do this, the back of the dryer needs to be removed. If you have power to the elements then check for continuity by removing the power leads and connect the test leads, one to each end. If there isn't any continuity then replace the elements.
May 17, 2009 | Whirlpool Dryers
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
MAGIC CHEF DRYER CYE2000AYW
eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Mar 05, 2008 | Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
