Tip & How-To about Washing Machines
To trouble shoot this problem please check this possibilities:--
The first thing to check out
in this problem is check the draining line in the washing machine. Check if the
drain line is got clogged or its getting blocked by any metal or dust object in
the pump. Also check in between the inner clothes tub and the outer tub which holds
the water. If the blockage is between the tubs, then it may clog the drain hose
which is connected to the pump. If you notice blockage in the pump, then remove
the hoses from the pump and clear the blocking material by removing it out.
But if the pump is clean and
clear and hoses are also seen clean then the other part to check is
outer tub part, for that you
will need to open the washer's main access panel and remove the rubber material
hose connecting the pump .the hose is
exactly connected to the bottom area of the outer tub. If you notice any
blockage/clogging in that area you can remove it with the help of pliers.
If you are not able to remove
the clog or if you can see but its seen in very inner area then you need to take
the agitator out, after removing the agitator remove the top of the outer drum
shield, and inner clothes tub. You will require some special tools to do the
job in this case.
But if inner tub, agitator
and other parts looks clean and clear then you need to check the drain pump. it
may be leaking or it may be worn out and got loose.
This is the basic checking
and troubleshooting you can do it yourself to resolve this issue of not
draining.
