Heating & Cooling Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG wall unit in my sun room. Geicos are coming into the room through the unit. Do you have a screen I can use to keep the Geicos out??
Anonymous
Level 3:
  • Master 455 Answers
  • Posted on Mar 19, 2010
Anonymous
Master
Level 3:
Answers
455
Questions
0
Helped
143098
Points
1102
At a hardware store ask for 1/4"bird screen to fashon a cover.It wont block air flow that the unit needs & keep the pests out.
How do I hook up remote thermostat to LG LP120CED?
Some thermostats have a five minuter time delay to protect the A/C when power fails. Some units also have a time delay, if so both must be satisfied before it will start.
1helpful
Just bought the TV yesterday. In the bright room, with sun shinning, i can not see the picture. Is there a setting that needs to be switced?
You didn't mention the make or model of your TV but most of the latest do have an ECO setting or similar idea in the set up or picture menu, this means the screen will automatically adjust the picture brightness if the room starts to get too bright, as in the sun shining or if the room gets too dark. Take a look in your instruction book for this type of setting, remember not all models have this & yours may be one of them.
Lg air conditioner keeps goin on and off, heat outside is 113 degrees is this affecting it
It very well could. Particularly, if the humidity is high and the AC unit is in direct sun light for 6 hours or more per day. If that's the case and it's either a window or thru the wall unit. Installing an awning over it will help.
1helpful
All three units turn off after 2 minutes
Make sure you have set them correctly IE/ If you want them to heat, make sure the heat symbol is dispalyed and the temperature setting is above the room temperature. Press the "house" symbol on the remote to find the room temperature. LG as with most other brands , if set to cooling but the remote temp is set high ( 20 to 25 degrees,) will run for a few minutes and then turn off as the machine thinks it has reached the temperature you have selected.. Heat symbol on LG is a "sun", cooling is an icicle. Check your filters.... if they are dirty, the units will not operate correctly.
How do I turn heat on for first time in lb wall unit
Keep heat mode and set temp +5 than your room temp. Helpful?
I have a glow warm 20000 btu natural gas unvented heater. The unit is wall mounted. It won't stay on for more than 15 minutes, then shuts itself off. Its in a corner if that makes a difference... but has...
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
2answers
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
What to buy?
there are units on the market that will work great, one is called a Mr, Slim, look it up on the internet and find a dealer in your area that carries them and check them out.
Top Heating & Cooling Experts
Paul Carew
john h
