Question about Lands Phones
Phone no longer rings GE phone would only make soft beep sound. Unplugged base from electrical outlet and makes a more audiable sound. No ring on cordless handset either.,
Posted by jwelch119 on
5 Related Answers
Anonymous
SOURCE: Handset No Link To Base error and no dial tone
My battery is a Ni-Cd. I bought it new on eBay (TL26554 battery number). I allowed the new battery to charge for a long time and then tried to see if it would work. But no go....the handset gave me the same error message. Good Luck to you too! Mmmmmm
Posted on Sep 18, 2007
Anonymous
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Posted on Nov 19, 2007
Anonymous
SOURCE: idect x1 cordless phone
the cordless connected on ups rings periodically without being called
Posted on Mar 08, 2008
Anonymous
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Posted on Jul 09, 2008
Anonymous
SOURCE: ge cordless phone model # 28111ee2-a is on do not distrub
There is a do not disturb button on the base of your phone - if it's red it's on. Press it to turn it off. It is on the main base and works for both headsets.
Posted on Jan 20, 2009
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
Jul 01, 2013 | Lands Phones
While talking on cordless other party's cell phone disconnected. Now all cordless Uniden phones are saying "Searching" and do not work - main phone rings but no caller ID.
Sounds like someone unplugged the power on the base station, or the power supply failed on that base station. Do you have a spare power supply? Is there power at the outlet?
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone
GE phone has stopped ringing
I had the exact same problem and tried everything. It wasn't until I unplugged and main base from the electrical outlet for a few minutes and plugged it back in -- for some reason that made everything work. It is worth a try. We had some minor electrical outages in the last week due to weather so I assume that screwed something up.
Feb 02, 2009 | Uniden Cordless Phone
I can't get incomming calls
When I press talk to make a call, it just beeps and turns off, there is no ring tone? There is a new battery and the charge light is lit when the phone is on the base. Please advise.
Dec 05, 2008 | GE Telephone pr521w
Can't make outside phone calls
#1. I discovered that satellite phones were too far away from base, so I moved them closer to the base.
#2. I unplugged all 3 satellites from electrical outlet, waited 10-15 mins., replugged them, and VOILA! Problem solved!
Thank you for answering.
lar52 - a happy customer.
Jun 25, 2008 | Panasonic KX-TG1033S Cordless Phone
Turn off ringer?
On the base, to turn the ringer off, press and hold Volume Down [V] until the unit beeps 2 times. On the handset you can use the menu to turn off ring. This way, you can choose to receive and take the urgent calls.
Apr 04, 2008 | Panasonic KX-TG2313 Cordless Phone
Ringer
Unplug the phone and plug it back in. Really. It just worked for me.
Dec 12, 2007 | GE 28112EE2 Cordless Phone
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
Lands Phones Logo
65 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
